K20 swap
Old Feb 7, 2009 | 10:49 PM
porkchop's Avatar
K20 swap
how difficult is it to swap with a k20
Old Feb 7, 2009 | 10:54 PM
spoonek4's Avatar
Hate to say this but u should be able to find TONS of information here by using the search function.....
Old Feb 7, 2009 | 10:56 PM
porkchop's Avatar
ok i heard about the k20 swap having poor traction have they fixed that with some part
cause i need traction for the 110 freeway
Old Feb 7, 2009 | 10:59 PM
Fitftw's Avatar
not sure where you heard traction problems. you'll probably have handling problems if anything with extra weight but coilovers fix that anyway. either way there is a TON of info on here and fitswap.org or was it com regarding this swap
Old Feb 7, 2009 | 11:04 PM
porkchop's Avatar
thanks with that engine and the supercharger that is on the website is that carb approved cause its my everyday car
Old Feb 7, 2009 | 11:12 PM
Spooling's Avatar
swap a K24 stroked to 25 or 26. combine that with a K20 head. or just a plain simple K20A2 type-S motor. A K20 weighs 30kgs more than the L15 so it's not THAT big of a concern. Why K24? because torque is more useful on the streets. But you need to upgrade your suspension and tires to actually USE that torque. or else you will be slow because, your tires are spinning like mad. like what happened to me yesterday.
Old Feb 16, 2009 | 09:28 PM
bluerice's Avatar
where did you hear that the k20 is only 30kg heavier than the L15 i thought it was supposed to be 110lbs heavier?
Old Feb 16, 2009 | 10:16 PM
redrumm's Avatar
if your not looking to make more than 200hp than K swap would be worthless.
Old Feb 19, 2009 | 04:14 PM
FELIXY69's Avatar
i want K20 !!! and will cost u $10k CND
alexfree05
57
Oct 15, 2021 10:43 AM
fightinghamster
Nov 20, 2014 12:19 AM
Bukwheat
Sep 25, 2008 07:02 PM
blackice
Sep 17, 2007 07:25 PM
j5ive
May 21, 2007 07:12 PM
