New speakers ruined my car
Old Feb 14, 2009 | 12:15 AM
TheKingRax's Avatar
Hey all,
I just installed 1 sony explode 300 watt 4-way speaker on my passenger side. I have an 09 Fit.
I turned on my radio and to my surprise it sounded a lot worse than the stock from the drivers side. It has no bass at all.
Everyone else who upgraded their speakers claims that it was an improvement. What's up with this?
Old Feb 14, 2009 | 01:18 AM
vince's Avatar
probably because the stock head unit does not have enough juice to power your speakers.
Old Feb 14, 2009 | 01:20 AM
OneFitWonder's Avatar
I noticed the same problem with my CDTs I just installed. I was hoping the factory HU would inch by with the power it has, but lack of power and legitimate eq controls mean I'm gonna have to axe it
Old Feb 14, 2009 | 02:03 AM
accordguyintake's Avatar
Yeah... The stock headunits are not the best. An amp or a new headunit will do much good
Old Feb 14, 2009 | 02:09 AM
fitster's Avatar
its also because its a sony explode
Old Feb 14, 2009 | 03:12 AM
Kyle is raaddd's Avatar
Master FitFaker. CHEA!
yeah you bought "walmart" speakers
Old Feb 14, 2009 | 11:18 AM
khanhdom's Avatar
lol exactly
Old Feb 15, 2009 | 12:11 AM
TheKingRax's Avatar
Ok ok i get it i bought horrible speakers. They are 270watt 50rms. I checked however and noticed they are 50hz - 23 khz. If i got something 30-35khz and 65 rms, would that still work with the stock head unit?
Old Feb 15, 2009 | 12:13 AM
solbrothers's Avatar
ive heard that the problem isnt the speakers, but its the headunit. people have had better results changing out the headunit, than changing out the speakers.
Old Feb 15, 2009 | 01:17 AM
Sugarphreak's Avatar
Push My Button
I agree, Sony Explode products are not very high quality.
Speaking about mid-range speakers specifically; I personally like Alpine, Pheonix Gold, Kicker and MB Quartz the best. If you are on a budget Clarion makes a good product as well; Sony and Kenwood stand out as the bottom of the barrel products to me.
Sony over-rates their products BIG TIME... if you tried to run that much power to them they would frap like crazy.
As long as you pick up a set of speakers from the brands I mentioned they don't need a lot of power to sound loud and the quality should be immediately apparent. As an example I have heard a Kicker sub running at 75watts easily out-pound a 300watt Kenwood sub. It kind of makes you shake your head sometimes at how much they can differ against the same measuring stick.
Old Feb 16, 2009 | 06:46 PM
jman245's Avatar
if u stay with the factory hhead u should get a speaker with high sensitivity levels to make up for the lack of power and lower if you are using an amp.people dont know that you can blow out spreakers if u under power them as well as over power.
Old Mar 4, 2009 | 11:34 PM
Pelletier's Avatar
i want to know if i put 4 speaker , an ampli and a sub if its can work with de factory head
Old Mar 9, 2009 | 01:09 PM
Rod2Rice's Avatar
get yourself some Infinity Kappas. I was running those for a bit with the OEM head unit in my 08 and it sounded great. The highs were a little TOO high, but just playing with the EQ solved that.
Old Mar 9, 2009 | 01:18 PM
DarkStorm's Avatar
This statement is 100% completely wrong, no offense to the poster. I just want to get the correct information out there. If this was the case every speaker in the world would blow because speakers aren't played at their rated power all the time. If you have ever turned down the volume, you are underpowering your speakers.
Now if you want to get specific, if you underpower a speaker with a frequency range it is not designed for you can kill it. EX: Play a 10,000 Hz sound at 100 watts on a 250 watt sub designed for 10-200 Hz. But I won't call this being underpowered, I would call this misuse. Speaker suspensions and cooling are designed to operate within the rated frequency range.
Tom Spahr
Sep 22, 2015 08:30 AM
polokid69
Jan 15, 2013 04:52 PM
Ciggy
Jun 28, 2008 02:17 PM
pwnstar
Jun 7, 2008 12:11 AM
lilcat
Jul 2, 2007 01:14 AM
