Help! Indash nav install
Old Feb 20, 2009 | 03:20 PM
garseeahh's Avatar
So i just bought the Pioneer f900bt and it came with two extra wires i dono where to connect. The manual says the pink cable is the car speed signal input and the violet white strip says its a reverse gear signal input. Do these wires actually need to be used and if so what and where do i connect them to?
Chris
Old Feb 20, 2009 | 03:47 PM
NIGHTHAWKSI's Avatar
vehicle speed sensor location..definatly connect this.
https://www.fitfreak.net/forums/fit-...-location.html
the reverse wire can be de-pinned or just taped off and not used, unless you have a back up camera. if you have a back up camera, use the sam turn on source that you used for the back up camera. wihtout having a wire diagram, the easiest wire to use for this would be to use the power wire that goes to the reverse bulb.
for future reference...www.avic411.com has ALOT of info about pioneer head units.
Old Feb 20, 2009 | 03:54 PM
garseeahh's Avatar
yeah im a retard... i google searched it then it poped up on FF.... but i guess the vss is the pink wire in the Scoshe harness
Old Feb 20, 2009 | 04:03 PM
not sure what wire it is in the kit...just follow pin 14 from the OEM harness and see which one it leads to on the scosche harness
Old Feb 20, 2009 | 04:05 PM
garseeahh's Avatar
yeah its literally a pink wire now in pin 14 on the scosche harness lol.. bond moment i guess... where did you end up stashing your gps ant?
Old Feb 20, 2009 | 04:09 PM
when the radio is out rach forward and left in the dash ....under near where the gauge cluster cover meets the actaul dash...there is a flat area that i double stuck taped (or maybe it was a peice of metal it is magnetized to...cant remember) the antennae to. works great. just reach your hand in that general area and you should be able to feel the area im talking about.
hopefully that makes more sense as your sitting in front of the radio, lol.
Old Feb 20, 2009 | 04:12 PM
garseeahh's Avatar
yeah im just wiring all the harness up right now then im off to install... another question before i do this... for your video bypass.. i saw on the avic forum that all you do is move the mute pin then ground it with the light green wire?
Old Feb 20, 2009 | 04:20 PM
i have the AVIC-d3. so mine might be different. but that sounds VERY familiar, it could be teh same for yours
Old Feb 20, 2009 | 05:11 PM
LaoSiFu's Avatar
Hey NIGHTHARKSI, you wouldn't mind posting picture of your AVIC-D3 so I can see. I am curious to see how the unit looks. Thanks
~Robert
Old Feb 28, 2009 | 02:26 PM
LaoSiFu's Avatar
~Robert
Bump Bump Bump
fitagent
Sep 16, 2023 06:14 PM
DeltaCommando5
Jan 7, 2019 04:07 PM
DonasGD
Jun 12, 2017 12:36 PM
ck42
Aug 8, 2013 12:46 AM
blythe
Aug 25, 2009 07:08 PM
