Afr?
Old Feb 24, 2009 | 12:20 PM
im the fit's Avatar
Afr?
Is a 13.8 AFR good or ok or ?
I have headers,cat delete, catback,CAI,weapon-r intake manifold,crank pulley.BTW i just installed AEM wideband.
Old Feb 24, 2009 | 05:43 PM
Mr_ET's Avatar
it's not bad but at WOT it should be closer to 13.0
Old Feb 24, 2009 | 08:31 PM
im the fit's Avatar
Any NA AFR's to compare?
Old Feb 24, 2009 | 08:34 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
Its too lean IMO. Hopefully youre running 93oct to save yourself from detonation.
You need a tune.
Old Feb 24, 2009 | 11:43 PM
im the fit's Avatar
for a quick fit could i change plugs or use smaller gap plugs?
Old Feb 25, 2009 | 01:02 AM
im the fit's Avatar
bump!!!!!!!!!!!!!!
Old Feb 25, 2009 | 01:06 AM
kelsodeez's Avatar
UNBANABLE
You need a tune.
i agree that he should be running 93 octane, but i believe proper afr at idle for the L15 is between 14.7 and 15.3. close to 13.0-13.5 at wot.
where did you install the o2 sensor on your test pipe?
Old Feb 25, 2009 | 01:13 AM
im the fit's Avatar
its about 16 or 17in and yes on the downpipe
Old Feb 25, 2009 | 01:29 AM
kelsodeez's Avatar
UNBANABLE
sorry, i meant is it at 10'clock or 2'oclock? because if it is at a bad angle, the o2 sensor will go bad very quickly and read extremely rich before they die.
also, sometimes if my fit idles for a long time, it will show its idling around 13.
Old Feb 25, 2009 | 01:32 AM
im the fit's Avatar
at 2'oclock
Old Feb 25, 2009 | 01:35 AM
kelsodeez's Avatar
UNBANABLE
well, if it keeps idling at 13, take it to a tuner and have them put a sniffer to your exhaust to see how accurate your wideband is.also, did you ever install an o2 fix to your testpipe for your stock o2 sensor?
i wouldnt see this as an immediate problem, but if you keep idling rich, it could lead to more problems down the road.
Old Feb 25, 2009 | 01:40 AM
im the fit's Avatar
it idles at 15 flat its the WOT running lean that im having trouble with
Old Feb 25, 2009 | 01:42 AM
kelsodeez's Avatar
UNBANABLE
ahh dude, you are all good then. 13.0 for an na engine that hasnt had any timing change is all good.
Old Feb 25, 2009 | 01:45 AM
im the fit's Avatar
ive seen it go to 13.8 up to 14.1
Old Feb 25, 2009 | 01:48 AM
kelsodeez's Avatar
UNBANABLE
its fine dude, i had the same anxiety with my car when i put my wideband in. i thought it ran super lean but when i got my service manual, it set all my worries aside. our cars just run lean. its the nature of the beast.
Old Feb 25, 2009 | 01:49 AM
im the fit's Avatar
Thats at WOT
Old Feb 25, 2009 | 02:00 AM
im the fit's Avatar
could i put the afr sensor next to the 02 or at the same length as the 02
Old Feb 25, 2009 | 02:01 AM
kylerwho's Avatar
spoon fed
is your car throwing a CEL?
if the stock o2 sensors are forcing a code then the fit will throw itself into a preset open loop mode. its not quite limp mode though.
at least that is how i understand it to work but i could be wrong.
Old Feb 25, 2009 | 02:09 AM
im the fit's Avatar
no I actually never had a cel light come on,but I just want to know if 13.8 to 14.1 is lean rich or normal
Old Feb 25, 2009 | 03:19 AM
quangalang's Avatar
for NA fit, that's not lean...
