Removing 05 Fit stereo unit?
Old Feb 28, 2009 | 11:48 AM
kaiser2000's Avatar
Hey all,
My gf has a 05 Jap import Fit which as a result has the stereo tuned to only range between 70 and 90 Mhz FM. I posted about this in another part of the forum but I've since discovered you can buy a "band expander" on places like Ebay that will retune the standard FM range (ie: 88-108 Mhz) to ones that this stereo can read.
Apparently these expanders connect to the aerial input at the back of the stereo itself, so my question is, how easy is it to remove the standard stereo in these cars? (pics/step-by-step would be great!)
Cheers!
Old Dec 16, 2009 | 11:05 PM
dogma's Avatar
I have this same problem also, managed to remove the panel below the air vent adjustments but can't see how to continue further.
Old Dec 17, 2009 | 05:23 AM
Type 100's Avatar
You'd have to go through the glovebox to remove the center console and the radio/headunit attached to it. Not the easiest job to do but possible. You'll need a socket wrench.
Try looking for the GD Fit electronic service manual, it should be posted somewhere around here.
Old Dec 31, 2009 | 05:04 AM
doug810's Avatar
kinda late but you can go to metraonline.com and look for the fit and you can look at the install guide for their dash kit
ImJoeShmoe
2nd Generation GE8 Specific Fit I.C.E. Sub-Forum
Jan 29, 2016 09:35 PM
wvucyclist
May 4, 2014 09:35 PM
Paddyfitjazz
Apr 27, 2010 06:23 AM
Bertgamble
Jun 28, 2009 08:38 PM
howardlhughes
Sep 6, 2005 11:20 AM
