Where do you mount your amplifier?
Old May 10, 2009 | 03:17 AM
kroze's Avatar
I wanted to put my amplifier somewhere where I can still have all the functionality & purpose of the fit's cargo room. I will not use a subwoofer btw. I'm just going to power all 4 speakers with it.
Where do you guys put it?
Old May 10, 2009 | 09:43 AM
Ciggy's Avatar
I HAD mine bolted to my back seat but eventually it fell off because the studs in the seat were to far apart for my specific amp. There's many places you can put it. Try bolting it up under the rear seat or to the side of the trunk.
Old May 10, 2009 | 09:54 AM
M@lew's Avatar
I have mine on the back of the rear seats. Whether its best to use on the "double" seats or the "single" one is debatable. I was going to have it put on the single but then due to miscommunication it got mounted on the double. :P Haven't had any problems with it but I have a rear strut and it fits perfectly between the strut and the seat, offering more protection from the things in my boot. When the seats are folded down, I think as long as nothing overly heavy goes on the amp it should be ok.
I was going to see if it could be mounted under one of the seats as well, but that looked like a lot of trouble.
Old May 10, 2009 | 11:40 AM
Daemione's Avatar
I've got mine on the back of the rear seat - drivers side. I was really hoping to slide it under a front seat or stash it down in the spare tire well for security purposes. But after spending a long time fooling around with it, couldn't find a solution that worked. The amp I'm using (eDesign NINe.4), just didn't fit well under anything.
Old May 13, 2009 | 02:54 AM
raton's Avatar
These amps installed under the driver's side seat:
JLA HD600/4; (10-13/16"W x 2"H x 8-7/8"D); 4-channel
Alpine PDX-5; (10-3/16"W x 2-1/2"H x 8-3/8"D); 5-channel
There is a metal bar under the seat (going left-to-right) so u have to mount the amp so the bar doesn't hit the amp.
The JL amp was mounted too far forward so couldn't move the seat all the way back. The Alpine amp was mounted further back so the seat could move all the way back.
My friend got in and said, "Oh, look...a foot rest."
Old May 13, 2009 | 06:46 PM
kroze's Avatar
damn, i got the factory all weather floor mat so i can't put anything under the seat & have the floor mat at the same time.
Old May 13, 2009 | 07:31 PM
raton's Avatar
Yeah, I got the all-season mats too and pulled 'em out on the rear-driver's side. Another FitFreak member w/ the Alpine amp layed the all-season mats over the amp--good to hide it from prying eyes.
Here's what someone else did (mrwilli):
Old May 22, 2009 | 02:28 PM
kroze's Avatar
That's awesome, do you have larger pics? & more of it?
Do you just drill/screw it onto the mat itself?
Old May 22, 2009 | 02:56 PM
raton's Avatar
That's pretty much all the pics I got. You can check this thread for more info (when I was also looking @ where to install my amp): https://www.fitfreak.net/forums/fit-...tml#post347929
Remove whatever mat you have & drill/screw (2 screws) the amp right through the factory carpet into the floor of the car. I had mine professionally installed though. They used a screw that just penetrated to the floor because the gas tank is below there too.
Old May 29, 2009 | 10:54 PM
reako's Avatar
Lookin good man! Once I figure out which brand I'm going with for the doors (leaning towards focal's) I'll go from there on to amp selection. Would be nice to have something like that Alpine with like 5 channels built in - keep everything clean and simple...already have power and signal back there to my existing sub, I could probably figure the rest out from there. The bitch of it will be running wires to the door speakers!!
Old May 30, 2009 | 10:38 PM
cool531's Avatar
spare tire
Old May 31, 2009 | 10:10 PM
M@lew's Avatar
Wow that's an awesome idea.
Old May 31, 2009 | 11:27 PM
ennjoi's Avatar
i have mine bolted/screwed behind the back seats
Old Jun 1, 2009 | 10:28 AM
MetalHead88's Avatar
be carefull with the amp in the tire like that. its gonna get really hot down there
Old Jun 1, 2009 | 01:35 PM
MarkyMark's Avatar
^ That Alpine is digital so it's not a problem
Old Jun 1, 2009 | 01:40 PM
deranged's Avatar
I put my alpine behind the single back seat. I was only going to power the speakers too but when thought about it a sub was needed. So got a 4 channel amp and powered the front speakers with it since thats where all your sound is anyways. Then used the other 2 channels for the 10 inch sub with a potted box. Sounds amazing and doesn't take up the whole trunk. That was my main concern. Still used the stock navi but had to install a hi/ok converter. The sound is amazing even with the stock speakers.
Old Jun 1, 2009 | 01:42 PM
deranged's Avatar
Ported box not potted. And hi/low converter. LOL. Dam iPhone spelling
Old Jun 6, 2009 | 02:38 AM
Lyon[Nightroad]'s Avatar
Originally Posted by cool531
spare tire
I'm glad someone else thought of it. I did pretty much the same thing. Only difference is I used a piece of plywood to strengthen the piece of shit 'floor' that is above the spare and then mounted the amp to the bottom that plywood. works great and you can chill on it with your girlfriend at the drive in movie without worrying about breaking or bending that crap.
Old Jun 6, 2009 | 02:34 PM
this is actually a great idea! im not really a big fan of hiding my gear. i like to look at it and be like "yeah. thats badass."
nicco
Jan 25, 2015 05:03 PM
sterVin
Jan 24, 2009 07:57 PM
Scaldy
Jan 23, 2009 11:29 PM
TomiGunz
May 18, 2007 06:50 PM
TomiGunz
Mar 9, 2007 03:28 PM
