Keyless Entry+Dome Light+Radio Not working
Old Nov 13, 2009 | 11:02 PM
ZiaMan's Avatar
I have been going through forums trying to see what the problem is, but i really cant find the answer. I have an aftermarket head unit installed, but i had it installed at bestbuy over a year ago. Recently i was messing around with the dome light, trying to replace the original bulb with LEDs. I saw a little spark, then the LEDs stopped working. I put the original bulb back in, and it still didnt work. I then noticed that neither my radio or my keyless entry system was working. If i have the car on, i can use the power locks, but if the car is off, nothing works. I checked the fuse, nothing looks bad. Any pointers? BTW I have a 08 fit sport, if that is of any use...
Old Nov 14, 2009 | 01:27 PM
binaryh4x's Avatar
I think I have done this before, it was the "backup" fuse in the panel.
Old Nov 14, 2009 | 02:07 PM
Kishore's Avatar
Check FS8 10Amps fuse in under hood fuse box.
Found my old post:
https://www.fitfreak.net/forums/1st-...oblem-gd3.html
Old Nov 14, 2009 | 02:10 PM
Dennis51's Avatar
Not sure if it's the same on earlier models, but on a 2009, it's almost definitely the "Backup Fuse", which is the top left corner one in the orange clip on the fusebox under the steering wheel. Mine popped during my maplight installation, and gave me the same symptoms: no lights, no radio, no door locks.
Found the answer here from helpful forum members.
Old Jun 2, 2017 | 09:17 AM
devmail's Avatar
Thanks for this post, just had a similar issue and it was the back-up fuse 10A in the engine bay fuse box.
Old Oct 6, 2022 | 08:43 PM
jacubby's Avatar
Back from the dead
Sorry to revive, but did you ever get this sorted out? I just bought a used 2008 5spd Fit (got a crazy deal on it) and it seems to have this issue... also, the OBD2 port has no power either (I'm guessing it's all connected).
All the fuses look good (I checked every single one of them). I'm fairly handy (I've done timing belts and valve jobs on B-series Integras, full suspension mods, clutch replacement, etc) but am stumped. I need to get the car inspected for title transfer soon.
Thanks. Looking forward to the fun journeys ahead.
MonstaMatt
Feb 14, 2026 10:10 PM
Globalksp
Apr 4, 2017 07:27 AM
fit to work
Feb 14, 2017 04:05 AM
single_digit
Feb 27, 2012 09:12 AM
Packy
May 16, 2009 09:34 PM
