Abs light and traction light on after lowering
Old Dec 10, 2009 | 12:16 AM
FitDEEZ's Avatar
so i lowerd my ge8 today and when i put everything back to gether my abs light is on and my traction control light is on .. i didnt mess up any wires.. so does anyone know what the problem could be or has anyone had this problem b4
Old Dec 10, 2009 | 12:17 AM
FitDEEZ's Avatar
pleasee helpp
Old Dec 10, 2009 | 01:04 AM
FitDEEZ's Avatar
looks like i gotta go to the dealer
Old Dec 10, 2009 | 01:32 AM
thefit09's Avatar
I know you said you didn't mess with the wires, but i could almost guarantee that's your problem. Did you triple check and make sure everything is secure and connected?
Old Dec 10, 2009 | 02:28 AM
HONDAMATIC's Avatar
yeah you better recheck i bet the abs wire got stretched and damaged
Old Dec 10, 2009 | 02:39 AM
vinn's Avatar
did you plug the ABS wire back? or stretched?
Old Dec 10, 2009 | 02:55 AM
FitDEEZ's Avatar
im gunna check tmrw ... if its damaged what could i do to fix it?
Old Dec 10, 2009 | 02:58 AM
FitDEEZ's Avatar
would the abs wire affect the traction light aswell?
Old Dec 10, 2009 | 07:22 AM
FitDEEZ's Avatar
any other ideas? in gunna check it out in about an hour
Old Dec 10, 2009 | 08:08 AM
BakedCookies's Avatar
yes most definitely, that's how basic traction control systems work, they utilize the abs to detect slip.
You had to disconnect the wire from the strut to get it off the car, but if you didn't remove it from the hub more than likely you stretched it and damaged it. Did you possibly hang it with the strut when pulling it out?
Old Dec 10, 2009 | 08:47 AM
Virtual's Avatar
Triple posts with little time passed make you look desperate. Let people reply to your posts before posting again, especially in the middle of the night.
There is an button that lets you change your own posts. Use it.
Old Dec 10, 2009 | 11:11 AM
mole177's Avatar
3 consecutive posts under an hour in the same thread.
haha.
who did the install?
prepare to spend some money getting the lines fixed.
as others have said, did you disconnect the abs lines?
Old Dec 10, 2009 | 11:32 PM
FitDEEZ's Avatar
i was desperate at the time .. but its all better now
Old Dec 11, 2009 | 06:09 PM
Choro-Q_Fit's Avatar
Glad to hear everything is OK now. What did you fix? BTW, your car is looking nice.
Old Dec 11, 2009 | 07:07 PM
FitDEEZ's Avatar
thanks have u seen my pic thread? it was kinda wierd i lowerd the front at night and drove it to work and i had the abs and traction light on then the next morning i did the rear and checked the wires... everything was ok so i turned the car on and the lights went off... its wierd but i hink the ar being like 2 inhes lower in the front aused the lights to come on
gyn9477
Jun 24, 2013 04:01 AM
Santiad
Mar 27, 2013 10:44 AM
123fit
Jan 10, 2010 06:07 PM
RandomKoko
Jan 30, 2009 05:18 PM
unphit
Dec 7, 2008 01:23 AM
