digital amp 10" sub do i need a cap?
Old Dec 10, 2009 | 03:28 PM
storm's Avatar
i use a 600 watt hiphonic amp and a 10" boston sub rated at 300 watts. .8 cub/ft. fiberglass box stuffed with fiber fill. what will a cap. do for me? thanks....
Old Dec 19, 2009 | 12:55 AM
Cap's Avatar
Cap
is it your only amp? if so, my opinion would be no, you do not need one.
Old Dec 22, 2009 | 03:07 AM
Col. Mustard's Avatar
Look on the side of your amplifier, if the fuses equal less than 30 AMPs total (sum of all the fuses on the amplifier chassis itself, NOT the wiring), you probably don't need to do anything at all.
If it is above 30 AMPs in total I still don't recommend using a capacitor unless you are too cheap to fix the real issue, which is insufficient alternator output and/or power delivery bottleneck.
One thing I do suggest is to upgrade your "big 3" wiring to 4AWG to allow as much current as possible to flow freely between your battery,alternator, and electrical equipment/chassis. If you still notice your lights dimming (more than usual), its time to get your alternator beefed up or replaced. Have fun!
Old Dec 22, 2009 | 05:12 PM
storm's Avatar
thank you.my sub amp is digital.my lights never dim.. i did up wire t 4ga. i like the sound. just wanted to see if any improvements would help. thank you for help...
short1
Aug 11, 2013 09:49 PM
Jaivee
SoCal Classifieds
Apr 12, 2012 04:11 AM
Vash
Nov 9, 2011 07:11 PM
OhNineFIT
Oct 16, 2010 10:59 AM
setter11
Feb 10, 2009 12:59 AM
