auto belt tensioner clicking?
Old Dec 17, 2009 | 01:58 PM
MNfit's Avatar
I have been hearing this loud clicking sound usually when I start my car after it sits over night. Looking around i finally found the culprit of the clicking, I circled it in red.
If im not mistaken isn't this the auto belt tensioner that came with the SC Kit? Why would this be making such a loud clicking noise and what do I need to do to stop it?
Old Dec 17, 2009 | 03:23 PM
aliencowboy's Avatar
Mine is making noise also, I adjusted the belt and it helped some.
I might pull mine off this week end and look at it.
Old Dec 17, 2009 | 05:03 PM
redrumm's Avatar
do it need to be oiled or anything?
Old Dec 17, 2009 | 05:39 PM
im the fit's Avatar
If anything use wheel bearing grease.
Old Feb 15, 2010 | 03:29 PM
Koi's Avatar
Koi
Was this actually a clicking/metallic sound, not the kind of squeal the belt can make?
I'm currently having the same issue if so - metallic clicking sound from a cold start, but with the addition of the smell of something burning until the car is warmed up, at which point they both go away.
Did you find a solution?
Old Feb 15, 2010 | 03:36 PM
MNfit's Avatar
You are going to want to check the belt and most likely replace it. Mine had worn down to almost half the thickness of its original size. You will also want to take a look at or keep a eye on your Kraftwerks auto tentioner. A week or so after my belt was replaced the tensioner failed because it was not properly tightened, snapping my new belt.
Old Feb 15, 2010 | 05:42 PM
Koi's Avatar
Koi
I'm going to have my mechanic check on the belt & tensioner as soon as I can. The belt's been on for less than 15,000 miles - could it really be that worn already?
Is there a specific process to testing if the tensioner is working properly or not? Thanks.
Edit: I just read your thread about the clicking noise & regarding the belt being worn down and stretched out. Do you think the tensioner having problems caused that prior to it completely seizing up and snapping the new belt? I'm definitely worried about the possibility now that this seems to be a likely culprit for my current problems.
Old Feb 15, 2010 | 08:22 PM
MNfit's Avatar
IT can get worn down pretty fast, mine was on for less then 15,000 miles. I realy hope that I dont have to be changing it out ever 15,000 miles though. Unfortunately I dont know how to test the tentioner, maybe Kraftwerks wold have a idea on how to.
Old Feb 16, 2010 | 04:36 PM
Koi's Avatar
Koi
Alright got my mechanic to take a look. He says everything looks fine for the most part - belt looks okay for now, tensioner is working fine. We just ended up tightening the alternator pulley a bit more in case the belt was slipping - I guess I'll have to see how things turn out in time.
The only thing that looked wrong was the idle pulley next to the tensioner is covered with grease or oil or something. There's a thick amount of black greasy gunk stuck to it - do you have the same issue?
EDIT: I mean the high speed belt control bearings, NOT THE PULLEY. My mistake.
Old Feb 16, 2010 | 06:06 PM
MNfit's Avatar
As far as im aware I dint have any thing like that. Did the tightening alternator get rid of the clicking noise?
Old Feb 16, 2010 | 07:46 PM
OJRKraftWerks's Avatar
Former Vendor
Gentlemen,
You need to make sure your belt drives are properly tensioned. The black "gunk" is belt dust from rubbing the tensioner underside. You have not properly tensioned your belt drive systems.
You must adjust your belt to proper tension so that the tensioner is not laying on its bottom stop (clicking noise) and the belt is not contacting the tensioner (belt dusting).
-Oscar Jr.
Old Feb 17, 2010 | 01:33 AM
Koi's Avatar
Koi
Sorry guys, I got the names of the parts mixed up so OJRKraftWerks might have given an answer to a question that wasn't asked correctly.
I meant to say the high speed belt control bearings, not the idle pulley / tensioner pulley, in regards to the black gunk. It seems likely that OJR replied regarding the tensioner's pulley due to my mixup, not regarding the bearings. I'll update this thread once I get a new answer back regarding the high speed control bearings, not a pulley.
Old Nov 25, 2010 | 11:06 PM
hazzard's Avatar
has any one replaced their belt yet and what belt did you use?
Old May 11, 2011 | 07:28 PM
monkeydave's Avatar
im getting a metallic noise under acceleration until warmed up then it is quiet i have no burning smell though, it has done this since new, anybody else got this
Old May 11, 2011 | 07:41 PM
JDMchris.com's Avatar
I run THIS
I have... Get the belt at www.kraftwerksusa.com
Old May 11, 2011 | 08:38 PM
monkeydave's Avatar
so we sure it is the belt /tensioner doing this noise and not the valves cam chain or gearbox, i guess thoses items wouldnt change when warmed up but the belt would
its hard for me to see where it is comming from as it is only there when i am driving and only for a min or two
Lucino
Mar 21, 2018 10:00 PM
mnapuran
Jun 11, 2016 06:00 PM
lakia5524
Jan 3, 2015 11:26 PM
lewjac3
Apr 10, 2013 01:53 AM
Marrk
Oct 23, 2009 07:32 PM
