Installing aftermarket HU question
Old Dec 27, 2009 | 02:12 AM
Nighthawk_GD3's Avatar
Well soon i am going to buy a new aftermarket HU and the Infinity Basslink ii. I want to do the install myself and i have a question about the vehicle stereo harness. Ill be using the supplied adapter harness from Crutchfield.com but from looking at page 4(http://www.handa-accessories.com/fit/musiclink.pdf) There are a good many connectors. I see the antenna connector but not sure which connector i will hook the receiver wire harness adapter to. If anyone could help i would greatly appreciate it.
Old Dec 27, 2009 | 05:27 AM
Wytt's Avatar
You only really need 2 adaptors/harnesses. The ones I use are Scosche HA10B (main wire harness) and HAAB (Antenna adaptor). And you just wire them up to the wire harness for the head unit.
Old Dec 27, 2009 | 02:13 PM
So once i actually get behind the factory unit and remove it it will be obvious which two connections i need?
Old Dec 27, 2009 | 04:13 PM
Wytt's Avatar
Yea, it just looks like a lot because of all the other stuff surrounding it.
Old Dec 27, 2009 | 04:29 PM
Cool thanks! Now i was looking at the back of the HU im going to purchase and it doesnt seem to have an antenna turn on lead or somewhere to hook up the REM cable from my amp. Can i just splice both the antenna adapter and REM from my amp into the "remote lead(blue w/white stripe)" wire from the HU wire harness?
Old Dec 27, 2009 | 07:02 PM
Wytt's Avatar
That I don't know... I just swapped out my headunit and that's all I done with it.
Speedlimitz
Sep 14, 2016 10:18 PM
Phamtastic
Mar 13, 2015 12:38 AM
vwli
2nd Generation GE8 Specific Fit I.C.E. Sub-Forum
Oct 4, 2013 07:43 PM
vwli
Jun 25, 2009 09:41 PM
xwikedonex
May 25, 2008 11:19 PM
