Fuse/Wire...?
Old Feb 17, 2010 | 04:45 PM
stock0891's Avatar
Fuse/Wire...?
Does anyone know what fuse or wire i can use if i want to tie into that power supply?
any advice or links to other posts would be greatly appriciated
thanks
Old Feb 18, 2010 | 12:17 AM
Fitting's Avatar
You talking about connecting to the battery?
The size of the wiring and fuse will depend on what you will be powering.
Old Feb 18, 2010 | 08:28 AM
stock0891's Avatar
yea the wire that actualy supplies the fogs with the power to turn on...
im pitting in accent lighting that i only want on when the fogs are on and i know that you can tie into the domelight so i was wondering if i could do the same thing with the foglights
Old Feb 18, 2010 | 09:28 AM
crash001's Avatar
I don't see why not check ur owners manual the fuse would probly be listed in there I think
Old Feb 18, 2010 | 09:46 AM
stock0891's Avatar
Thats the problem i did and i cant find anything unless i am looking in the wrong place
Old Feb 19, 2010 | 09:28 AM
stock0891's Avatar
Dose anyone else have any idea of what i can do?
Old Feb 19, 2010 | 02:53 PM
Fitting's Avatar
Pull the fusebox cover off and on there it will tell you which fuse is for the fogs. Go to any automotive store and get a fuse tapper. Connect the fuse tapper to what you want to power. Make sure you don't add to much lights to that circuit cause it would overload it.
Old Feb 19, 2010 | 04:32 PM
stock0891's Avatar
that actually helps alot thank you
Old Feb 20, 2010 | 12:46 AM
shazaam's Avatar
or run a relay off the fuse you want n run power directly from the bat. to whatever you're planning on lighting up. safer for the most part.
Old Feb 20, 2010 | 04:06 AM
crash001's Avatar
If u can't find it on the fuse box park near a wall turn the fogs on pull one out at a time and replace them untill u find the right one then tap it from there good luck
SilverEX15
Aug 30, 2014 09:54 PM
SilverEX15
Aug 25, 2014 08:29 AM
Gaffer
Jul 15, 2014 09:22 AM
Foots
May 19, 2012 05:29 PM
Fat Ping Cat
Jul 5, 2008 12:34 AM
