basslink and f900bt question
Old Mar 9, 2010 | 06:25 PM
AlphaQuad's Avatar
Hi guys,
I have a pioneer f900bt that is connected to my speakers through the speaker level outputs and I would like to add the basslink to the setup. My question is can I just connect the basslink to the subwoofer output from the f900bt which is a subwoofer line-level output or do I have to splice the rear or fron speaker level outputs and connect it from there? and also If i connect through the subwoofer output I dont have to connect the remote from the basslink because I can control it form my head unit? any advice would be appreciated
Thanks
Old Mar 12, 2010 | 09:42 PM
beatle's Avatar
I put a Basslink in my wife's Civic. It takes line-level inputs for signal, but you will still need the remote turn-on lead connected from the headunit as well, or it will not power on.
Old Mar 12, 2010 | 11:37 PM
feared's Avatar
rcas and remote turn on from headunit to the basslink.
you still need remote turn on, since the rcas only send the signal for the audio, not anything that would turn on the amp in the basslink.
Old Mar 13, 2010 | 12:19 PM
SD_MR_FIT's Avatar
connect the blue wires from your headunit to your remote wire on your basslink. then hook up your rca's. and you will be straight.
right now im running on the stock unit, so i taped into a fuse for my remote wire
ieandro
Oct 5, 2018 11:48 AM
TIfT
Jan 30, 2015 01:34 AM
rafnap
Mar 4, 2011 08:49 PM
yasirfaheem
Oct 21, 2007 12:14 AM
taffit07
May 15, 2007 01:39 PM
