Headlight Swap
Old Mar 16, 2010 | 12:26 AM
droopa's Avatar
Headlight Swap
i got me some new lights for my 08 Fit.
i'd like to wire my headlights so that once i go to hi beam, both the low beam and hi beam lights up. Currently only one is allowed to light at one time.
Can anyone advise me how to do this please?
Old Mar 16, 2010 | 02:14 AM
mdbrich's Avatar
Speaking for the GE model. The highs and low, use the same bulb. So only one setting can be on at a time.
Old Mar 16, 2010 | 06:38 PM
FITMugen's Avatar
If you change your headlights to aftermarket projector headlights, you can wire both high and low beam to be on when you turn the high beam on.
Old Mar 17, 2010 | 12:19 AM
droopa's Avatar
but the question is how do i do it?
do i need to use a relay or something?
Old Mar 24, 2010 | 08:09 PM
droopa's Avatar
anyone .....can you help me please?
Old Mar 24, 2010 | 08:41 PM
FITMugen's Avatar
If I were you, this was I would do to accomplish the goal.
Buy or custom wire with relay. Both low beams will get power directly from the battery. However, use OEM low or high beam to trigger the relay. So it won't void your car warranty since you do not modify any OEM harness. Additional, you can return to stock without a trace.
Please let me know if you need more clarification or diagram.
Old Mar 25, 2010 | 12:12 AM
droopa's Avatar
more clarification and a diagram will be needed. thanks in advance!
Old Mar 25, 2010 | 07:23 PM
FITMugen's Avatar
Please look at this URL. Please let me know if you still need help.
simple headlight relay wiring
zaobfit
Nov 22, 2014 09:02 AM
Muster
Jul 20, 2011 05:17 PM
IVTEC
Dec 25, 2009 10:37 PM
jaythomas
16
Feb 13, 2009 01:06 AM
atran21
Apr 23, 2008 01:20 PM
