Sponsored by:
Sponsored by: CARiD
Perform Shunt inorder to Repair the Low Beam Headlamps.
Old Apr 7, 2010 | 07:42 PM
nighthawk fit's Avatar
Angry Perform Shunt inorder to Repair the Low Beam Headlamps.
Hey Honda you have a problem with your 2007 Honda Fits? On 4/5/10 after three years my Low Beam Headlamps went out together and getting home in the dark sure was fun driving with my High Beams on!!! So i took my 2007 Honda Fit Sport into my Local Automotive Repair shop. And I took along a letter that another 2007 Honda Fit Owner had the same problem (I finally tracked down the cause of my low beams failing, and it's not the headlight switch. Here's the deal, and also the reason why changing the switch works for a while, but not for good. The culprit is a bit of corroded wire leading into the plug that goes into the headlight switch. When you pull out the plug to change the switch, that bit of wire gets jiggled and electricity passes thru it again, until the corrosion comes back.) This dude goes on to say (Here's the lousy part. The bad wire, at least on my 2007 fit, is the piece that goes right into the plug. My mechanic was able to scrape away the corrosion but says the plug and a few inches of wire leading to it, should be replaced or the problem will eventually return. But HONDA does sell the plug/wires except as part of the entire instrument cluster harness, which costs about $800.00
The Problem is an Open Low Beam Groung Wire 2 the Switch due to connector resistance.
Well my fix cost me $175.00 and my Repair shop Performed a SHUNT inorder to repair the Low Beam Headlamps. As they put it "They Performed Wiring Repair due to Overloaded Circuit at the switch that cost $84.95 and HEADLAMP SWITCH Remove & Replace $67.96 Total Cost Labor $152.91 Parts $9.94 Tax $11.40= $174.25
Old Apr 10, 2010 | 12:39 PM
E = Mc2's Avatar
This sounds like something that happened with the 86-88 Ford Escort GT. Ford used the same harness for the GT model as it did with the LX. The big problem was that the LX wasn't available with fog lights and the GT came with them. The lead which ran from the multi switch (turn, hi beam, w/s wipers) to the fog lamps wasn't heavy enough to carry the amperage required. Ford never issued a recall, instead opting for the TSB route.
The fix in the case of the Escort required replacement of a melted harness end and a heavier gauge wire. It seems to me that you should be able to disassemble the offending plug end and put a new wire in there. Your dealer should have the actual wire ends in stock, I would think.
Old Apr 10, 2010 | 06:40 PM
Thanks for the info E=MC2 but I don't go back to the dealer after being screwed by them too many times. But I would like Honda to talk about this problem they should have know about the power to the headlamps, sure it didn't happen until 3 years later but I feel they screwed up.
Old Apr 11, 2010 | 04:41 AM
BraytonAK's Avatar
Isn't there a kind of dielectric grease that you can put on the connection to seal out the atmosphere from causing this corrosion?
Old Apr 13, 2010 | 07:47 AM
BraytonAK could be but when it comes to fixing my Fit I just pull out my Wallet.
Old Nov 8, 2010 | 11:53 AM
urkfit's Avatar
Feds are investigating this now:
https://www-odi.nhtsa.dot.gov
NHTSA Action Number: NHTSA Recall Campaign Number: PE10037 N/A Make: HONDA Model: FIT Manufacturer : HONDA (AMERICAN HONDA MOTOR CO.) Year : 2007 Component :
EXTERIOR LIGHTING:HEADLIGHTS:SWITCH
EXTERIOR LIGHTING:HEADLIGHTS:HIGH/LOW BEAM DIMMER SWITCH
Date Investigation Opened : September 16, 2010 Date Investigation Closed : Open Summary:
The Office of Defects Investigation has received eight reports from consumers alleging the low beam headlights stopped working. Several of the complainants report having a wiring harness connector and headlight switch replaced as the repair.
hillsmagee
Jun 30, 2016 04:04 PM
dhk
Jun 4, 2015 07:19 AM
einstein77
Feb 10, 2011 01:55 PM
hifocused
Jul 22, 2010 12:48 AM
atran21
Apr 23, 2008 01:20 PM
