OZ Alleggerita HLT
Old Apr 12, 2010 | 10:48 AM
B-Blue's Avatar
OZ Alleggerita HLT
I've been trying to find a set of blue wheels, and most don't make them with a +45 offset (tons in +40 offset). But I found these from OZ. Here are the specs:
HOle Pattern: 4x100
Offset: +44
Weight: 6.29kg
They do have a 16x7, but it only comes in a +37 offset
Now the other problem I have is buying them! Tirerack has them, but they don't even list it for the Fit. And I have no idea where else to buy them.
Old Apr 12, 2010 | 11:00 AM
B-Blue's Avatar
I've talked to TireRack and they said it just wont fit? Why would that be? I've seen them have 17x7.5 with a +38 offset. So why wouldn't they fit?
Old Apr 13, 2010 | 01:22 AM
nghtrydr23's Avatar
16x7 +37 will fit with no rubbing. don't listen to them. honestly the person you spoke to was looking at a computer with preset configurations already and prolly dont know jack shit about what those numbers are. they are doing this so you can't go after them if something were to happen.
Old Apr 13, 2010 | 02:02 AM
Hootie's Avatar
^ On a GD that wouldn't be too much of a problem, but a GE is a different story.
Give this threads a read. Going by your previous posts and avatar you own a GE8 and according to the thread below. You would have to have the fenders rolled to run the 16x7 +37s and you can run the 17x7 +44 without rubbing as long as you don't lower, if you do lower, you may have to roll the fenders, add camber, trim the rear bumper, tuck the fender liners, or a combination of these to make it work.
https://www.fitfreak.net/forums/2nd-...ng-thread.html
https://www.fitfreak.net/forums/2nd-...s-caution.html
Old Apr 13, 2010 | 02:20 AM
s.gaspar's Avatar
maybe the hub bore is different thats why they're saying it wont fit idk
Old Apr 13, 2010 | 02:52 AM
j1nNju1c3's Avatar
Weird thing is AJ-Racing's Fit is lowered and they run 17x7.5+42 and they don't rub. I have 17x7.5 + 40 and I don't rub but I'm not lowered yet.
I'm just saying though.
Old Apr 13, 2010 | 09:58 AM
B-Blue's Avatar
See that's the thing, I see that some run at +40 & lowered, no issues. Others say they've done it too and have had rubbing issues, weird.
Old Apr 13, 2010 | 04:56 PM
lilaznphatboy's Avatar
what is the GE8 bore size?
Old Apr 13, 2010 | 08:48 PM
Type 100's Avatar
On the GD it was 55.1mm measured with a vernier caliper.
I'm pretty sure the GE hub size is the same.
Old Apr 13, 2010 | 08:53 PM
thefit09's Avatar
Like people have said, it really depends how low you are. I rub fairly easy on hard turns and over bumps, but I'm pretty low on eibach sportlines.
mikeGe82012
May 28, 2017 12:11 AM
linnboi
Jul 20, 2012 12:43 AM
Scaldy
May 1, 2009 09:44 PM
sbualuba
Jan 31, 2009 02:04 PM
J.P.
Feb 21, 2007 01:48 AM
