Heater/AC blower fan only works on high‎
Old Apr 16, 2010 | 08:35 PM
Mark T's Avatar
I am having trouble figuring this one out. I find info about other vehicles but nothing on 09 Fit.
The blower will not work on any setting but the highest. Heat and AC both still work but I have to set the fan to full blast. The AC compressor still comes on with the fan setting in positions other than high.
Any ideas what is going on here?
Old Apr 16, 2010 | 09:24 PM
Btrthnezr3's Avatar
Something's going on--I have read it somewhere...
Check out this thread...
https://www.fitfreak.net/forums/2nd-...l-1-3-out.html
Old Apr 28, 2010 | 05:36 PM
DRGW_Tunnelmotor's Avatar
Probably the blower motor transistor, I remember replacing dozens of these on accords & odysseys.
Old May 23, 2010 | 11:56 PM
F!TzME's Avatar
Excessive current draw from the HVAC blower motor
causes the blower resistor to fail.
Replace the HVAC blower motor and the blower
resistor to fix this problem
Old May 10, 2011 | 10:57 AM
AugeesFit's Avatar
Having the same issue. Mine is still under warranty, do you guys think I can bring it to the dealer and have them fix it? Thanks.
Old May 10, 2011 | 11:19 AM
Krimson_Cardnal's Avatar
I wouldn't hesitate.
Old Jun 5, 2011 | 10:40 PM
bkrell's Avatar
Awesome. Mine went out today!
Old Nov 16, 2024 | 10:52 AM
Jazu's Avatar
The reason is likely the motor control module failure due to excessive heat (older Honda's had them partially installed in the air intake plenum to cool the thermistor). Excessive heat is caused by not replacing the cabin air filter often enough resulting in lower air flowrates that leads to the thermistor overheating - thus failing.
scarvalho
Oct 26, 2020 11:50 AM
kakrohn
Aug 31, 2020 04:13 PM
sdashia
Jun 19, 2019 08:17 PM
seanpatrickk
Aug 10, 2015 07:32 PM
DGFitness
Feb 20, 2011 10:40 AM
