Need help with offset!
Old May 26, 2010 | 11:24 PM
ohanahuichubbz's Avatar
So, Ive bought my tw 2010 fit sport for about 3 weeks now and I have been looking around for new wheels..
Heres my situation...I will be sitting on megan coilovers pretty soon and i was wondering if i should go 15's or 16's most likely X7. Ive been searching around and saw that some people run +40 or less and some say +45 at least. I want to look at least flush with the fenders (I might consider rolling a bit if needed).
Also, any suggestions on styles of wheels? I am on a pretty tight budget (350-500 max).
Oh, and one more thing...what size tires should i run?
Any input would be appreciated.
Old May 26, 2010 | 11:26 PM
JDMchris.com's Avatar
I run THIS
your good if you run a +38 or more without very much rubbing. for a 15x7 i would use a 205/50/15 and for a 16x7 a 205/45/16
Old May 27, 2010 | 01:21 AM
thanks for your input jdmchris. any recommendations for my budget?
Old May 27, 2010 | 02:37 AM
I run THIS
A good wheel in that 300-500 range is the Buddy club P1, other wise it looks like a good choice for you will be Rota/drag/xxr etc
Old May 27, 2010 | 10:30 AM
score04w's Avatar
Thats a pretty good price range. I would go with 16's. i think 15's will look too small. 205/45 is good, just like chris said.
Old May 27, 2010 | 04:45 PM
if only the buddy club p1s come in gold....what other styles (in gold) do you guys recommend?
Old May 27, 2010 | 04:48 PM
Btrthnezr3's Avatar
Rota has lots of styles in gold...check out JLBMotorsports.com
Old May 27, 2010 | 05:00 PM
GD3_Wagoon's Avatar
how much do you plan to drop your Fit after you get the megan coilovers? a 15x7 +40 wheel on 205/50/15's will rub with even a mild 2 inch drop. any advice without more information is just speculation. although, you're going to have to expect to roll your fenders if you plan on running wider wheels with lower offsets. the question you should be asking is how much rolling/pulling will you need to save your sidewalls
Old May 27, 2010 | 05:01 PM
DreaMv's Avatar
Old May 27, 2010 | 06:40 PM
im not sure how much im going to drop my fit but i want to go pretty low. so i wont be able to run 16s w/ +40?.
thanks dreamv are the prices on the site firm?
Old May 27, 2010 | 06:45 PM
DreaMv's Avatar
you can contact jlb and you can always work out a package deal andd ask for anything in particular, they're REALLY helpful, either through email or phone... they're located in corona, CA.
Old May 27, 2010 | 07:40 PM
GD3_Wagoon's Avatar
16x7 +40 is fine with the tire spec that chris mentioned (205/45/16) but you will still have to roll your fenders. how low and how much camber you're able to add (front wheels only) will dictate how much rolling/pulling you'll have to do to the fenders.
i've run both 15x7+40 rota slips on 205/50/15 falken ziex and 16x7+40 rota j-mags on 205/45/16 reiken raptor tires. both wheel set-ups rubbed when i was fairly low on skunk2 pro-c's. all i needed was a light fender roll and -1.5 degrees of camber on the front wheels to avoid rubbing.
Old May 27, 2010 | 07:52 PM
I run THIS
I run a 15x7 +38 205/50/15 ziex minimal rubbing on hard cornering... ran 16x7 with 205/45 ES100 with minimal rubbing on hard cornering 16x7 +42 205/45 ES100 no rubbing. 15x6.5 +32 205/50 ES100 RUBBED 16x7+40 205/45 Ziex no rubbing 15x7 +41 205/15 Azenis no rubbing
Old May 27, 2010 | 11:55 PM
doctordoom's Avatar
Supervillain
i have 15x7 +48 wrapped in 205/50/15 azenis and it rubbed the front fender clips on hard bumps/turns. of course, our suspension and ride height makes a difference, so maybe that's why you had no rubs when i did.
be prepared to have to do something if it rubs, even if it's minor like removing the clips and using zipties.
Old May 31, 2010 | 03:18 AM
thanks for the input everyone....i think i know what to do. ill probably try 16x7 with +40 and roll my fenders a bit.
Old Jun 10, 2010 | 06:28 PM
nghtrydr23's Avatar
you should be fine with that, some guy had 16x7 plus 35 with no rubbing issues on a 2nd gen lowered on t1r springs
ciref8
17
May 12, 2012 10:57 AM
thebluepotato
29
May 3, 2010 11:14 AM
jazz_do_it
Feb 14, 2010 09:09 AM
WhaTisJDM?
Nov 29, 2007 09:29 PM
pastafarian
Nov 26, 2007 06:35 PM
