getting 16x7 +35 wheels, need tire help
Old Feb 16, 2012 | 02:56 PM
ciref8's Avatar
im lowered on t1r s-coils and im having trouble deciding between 195/45/16 and 205/45/16
Old Feb 17, 2012 | 06:12 PM
royalflush313's Avatar
Im running RS-R Superdowns with 16x7 +35 offset, 205/45/16 and there is no rubbing.
The rear could probably come out another 5mm to be flush with the fenders, the front is pretty tight and actually sticks out a little bit.
Right now I'm seeing if I could move to 50 series tires and have no rubs, but I have a feeling it might.
Old Feb 17, 2012 | 06:15 PM
ciref8's Avatar
awesome, thanks. I'm actually on the fence about these wheels now, they are gun metal rota rb. Im not sure how theyll look on my fit.
Old Feb 17, 2012 | 06:22 PM
The next set of wheels I buy will be 16x7 +40 all the way around with 10mm spacers in the back (or something in that dimension).
I don't rub now but I wouldn't mind the front wheels to be tucked in further just a touch.
Old Feb 18, 2012 | 03:55 PM
MNfit's Avatar
If that is your Fit as your avatar gunmetal rims would look fine on your car.
Old Feb 18, 2012 | 07:48 PM
ciref8's Avatar
im also looking at some 16x7 +40 konig runaways which i think might look better although they are a bit pricier
Old Mar 28, 2012 | 11:24 PM
phenoyz's Avatar
what about 15x7 with Offset: 37mm
will it rub?
Old Mar 29, 2012 | 12:08 AM
ThEvil0nE's Avatar
will it rub?
slammed? now that would nice... camber up front and prolly some fender rolls should fix that
Old May 8, 2012 | 02:26 PM
blanka98's Avatar
These are my Rota's 16x7 +38 mounted on 205/45/16. I'm lowered on DF210's
Old May 8, 2012 | 08:10 PM
solbrothers's Avatar
that's lowered?
Old May 8, 2012 | 08:22 PM
blanka98's Avatar
that's lowered?
205/50/16's would fill in the gap pretty well. With the 205/45/16, my speedometer is off by 3.5mph.
Old May 9, 2012 | 01:42 AM
eluune's Avatar
any rubbing issues so far? i've got similar spec wheels and was wondering if i should go with df210s or not. thanks!
Old May 9, 2012 | 12:40 PM
blanka98's Avatar
No rubbing at all! Just make sure your tires are 205/45/16. I don't know if these will rub with stock tires or 205/50/16's
Old May 9, 2012 | 01:33 PM
JDMxGE8's Avatar
Don't tell me you bought actual Rays Engineering stickers and slapped them on your Rotas...
Old May 9, 2012 | 04:04 PM
bmxman's Avatar
lol exactly what I was thinking...if you're going to roll the fake sh!t be proud of it!!
Old May 9, 2012 | 10:45 PM
SickFit's Avatar
for those not sure what tire size to get for 16s, get 195/50/16. Your welcome.
Old May 9, 2012 | 10:55 PM
Take those stickers off.
Old May 12, 2012 | 10:57 AM
Badwrench's Avatar
205/50 will rub unless you dial in some camber and do fender mods. I am running that size on stock wheels and rub all the time (2-3 times a day). Almost completely worn through my fender liner even though it is already trimmed away on the front.
BTW, I am dropped on TeinS springs and drive semi conservative. Most times it rubs is on dips in the freeway.
Go with 195/50 and just a touch of camber and you will be fine.
JDM:MaSongTray
Jul 12, 2013 10:45 PM
JDM-Taffeta-S
19
Oct 4, 2011 06:15 PM
thebluepotato
29
May 3, 2010 11:14 AM
andyd
Mar 13, 2008 07:17 AM
WhaTisJDM?
Nov 29, 2007 09:29 PM
