Where's the DLC?
Old May 29, 2006 | 04:45 PM
honda07fit's Avatar
Where's the DLC?
Can anybody describe for me the location of the data link connector (the OBD II diagnostic connector)? In my VW it was just under the lip of the driver's dash - no covers or anything - super easy to get to. I looked around some and couldn't find it. Do I need to remove any panels or covers?
In case you're wondering, I've got the VAG-COM tool left over from my VW days and it can read the generic readiness codes on Hondas so I wanted to check it out...
TIA
Old May 31, 2006 | 06:24 AM
honda07fit's Avatar
bump...
anyone???
Old May 31, 2006 | 06:47 AM
sillypuddy's Avatar
Someone that Posts too much
if you look under the steering wheel section of the dash, you should see it next to the middle ..
-joe
Old May 31, 2006 | 04:08 PM
honda07fit's Avatar
Thumbs up
Sillypuddy - Thanks - with your help I found it - spot on.
Old May 31, 2006 | 08:01 PM
sillypuddy's Avatar
did it work?
i have my OBD scanner from Techtom and it didn't work at all
-joe
Old Jun 1, 2006 | 04:58 PM
honda07fit's Avatar
Originally Posted by sillypuddy
did it work?
-joe
I haven't got that far along yet. I'll try it in the next couple of days and let you know.
Old Jun 3, 2006 | 10:26 AM
honda07fit's Avatar
did it work?
-joe
Hey sillypuddy - yep it worked. Doesn't give a great deal of info like it would on a VW, but it shows DTCs, pending DTCs, and some other good stuff like short and long term fuel trim. I mostly wanted to find the coolant temp - car pretty much runs at 80 c and cooling fan comes on at 98 c.
Old Jun 3, 2006 | 10:30 AM
sillypuddy's Avatar
thanks
can you send me the model of the vag-com you used?
-joe
Old Jun 3, 2006 | 10:37 AM
honda07fit's Avatar
I used the USB version of their HEX + CAN
I got the CAN version because IIRC I read somewhere that it'll be the required protocol on all cars at some point.
storm
Jul 28, 2010 08:52 PM
manxman
Jun 25, 2009 12:16 PM
Rocks A GD3
May 23, 2009 08:59 PM
firstshadow
Aug 22, 2006 07:49 PM
Jonniedee
May 29, 2006 01:11 PM
