Jerky car?
Old Jun 24, 2010 | 12:41 PM
hqly's Avatar
Jerky car?
Yesterday i noticed that my engine light came on. As I merged onto the freeway, my car started jerking at about 45 mph.. when I got on i hit traffic.. so goign 25-30 mph was okay.. it jerked once or twice when i gassed. When traffic cleared up a little and i was up to 45-50.. it jerked a little more.. the feeling when i step on the gas is that it vibrates and rattle a little while the car jerks.. liek not enough gas going through..
anyone experience something similar?? Or know what it may be?
Old Jun 24, 2010 | 12:51 PM
Krimson_Cardnal's Avatar
Possible miss-fire??? No way to know without codes. Take it some where for diagnosis - preferably a qualified repair shop that knows vtech engines. Miss-fires no good for cat-converters, so don't dilly.
Old Jun 24, 2010 | 01:33 PM
gd3vbp's Avatar
Theres a lot of threads on this floating around right now. It seems to be a common issue, take it to a dealership, the more documentation Honda has the better, hopefully they'll issue a recall or service bulletin to help everyone out.
Originally Posted by Krimson Cardnal
vtech engines
Old Jun 25, 2010 | 03:02 AM
doctordoom's Avatar
Supervillain
yeah with all these threads i'm starting to get paranoid
Old Jun 25, 2010 | 06:54 AM
gd3vbp's Avatar
I'm in the same boat. I'm only at 31k, so hopefully someone pins down a solution before i get up there in miles.
Old Jun 25, 2010 | 09:12 AM
What might help others is to know the year/model and mileage of your ride. Any progress on your end???
Old Jun 25, 2010 | 11:23 AM
hqly's Avatar
06 Fit.. i found out that when gassing, if it goes above 3500 rmp, it shakes and the mph does not go up.. it has a hard time changing ger to drop the rpm back.. so i'd imagine trying to merge on a freeway is very dangerous.. I put it in neutral and when i gave it gas.. same thing happen in neutral.. Honda wants $200 to diagnos. I'm thinking about just replacing the coil and take my chance?
Old Jun 25, 2010 | 11:33 AM
WOW - $200 to pull codes, that's outrageous. Either that or spend the money on a Scanguage. Really not a good idea the start throwing parts at it without knowing which parts to throw... things get really confusing fast.
Curious thing - on my 1996 Cadillac Sedan Deville I can pull codes right off the dash by pushing the AC "on" and "warmer" buttons at the same time. Can cycle through all sub-systems and codes and clear codes as well. I can tell I'm gonna miss that.
Old Jun 27, 2010 | 09:25 PM
hqly's Avatar
The dealership said he reset the system and that has resolve the P2647 code. However, my cruise and sport feature is still out. He said maybe a drive reel problem? have to bring it in again.
Anyone know what it would cost to fix a drive reel problem or something along that line?
They said there's no signal to my sport feature and cruise control.
Old Jun 27, 2010 | 09:32 PM
No signal could mean a blown fuse - no idea on a drive reel - the reset cleared up the problem?? How's the oil levels?
Certainly post progress - keep this the "official" thread, lot easier and less confusing to my tired brain....
Old Jun 28, 2010 | 03:22 PM
hqly's Avatar
it's not a blown fuse for sure because i checked all the fuses.
well they told me it'll be 220 to diagnos and at least 300 to fix if it's a simple fix.. i will hold off.. maybe someone else who have the same issue can share their experience later in time.. Hopefully it's some sort of connection issue..
Old Jun 28, 2010 | 03:33 PM
Old Jun 28, 2010 | 03:43 PM
Selden's Avatar
Are Honda diagnostic codes consistant across models? If so: Here's a list of OBD2 codes
Old Jun 28, 2010 | 03:59 PM
This is the simple conclusion I came up with. "Lesson Learned" probably the best you might do w/out getting into it further.
Dealer knows the switch most likely needs replacing, hence the repair estimate. Diagnosing is tacked on, however, it involves more than simply running codes. Tech must be able to pinpoint the problem and it can be more than one issue.
EDIT: Search threads for P2647 been discussed Look here as well: https://www.fitfreak.net/forums/1st-...tml#post876556
P2646 and P2647 are both related to the Rocker Arm Oil Pressure Switch Circuit
P2648 and P2649 are both related to the Rocker Arm Oil Control Solenoid Circuit.
It seems these codes show up as intermittent problem at times and can be related to oil pressure/levels.
Lesson here seems to reinforce to need to run at correct oil levels - be sure to post back any future issues.
Old Jun 28, 2010 | 05:05 PM
gd3vbp's Avatar
From the dealership days, they're pretty universal. That is unless you've got something european.
Old Jun 28, 2010 | 06:45 PM
hqly's Avatar
Originally Posted by Krimson_Cardnal
I knew about this and my car was fixed reagrding the check engine light.
The cruise and sport feature issues do not have anything to dow ith the CIL nor the P code.
Old Jun 28, 2010 | 06:48 PM
hqly's Avatar
The problem i have with the cruise control and sport feature has nothign to dow ith the check engine light and code P2647, or so they say.
He said something about the drive reel for the cruise control and indicated that the other problem may be because of the same reason.
Hardly_Ideal
May 20, 2019 12:13 PM
drgshah
Feb 11, 2014 02:56 AM
mrpooh
Nov 8, 2012 10:50 AM
FUKNDUBN
Oct 25, 2011 11:18 AM
ny111
Sep 6, 2010 11:44 PM
