My Fit has 67,500 miles - what maintenance should I be getting ready for?
Old Sep 13, 2010 | 07:02 PM
Edison Carasio's Avatar
So I've stopped driving my Fit so much and moved on to my CRX as the daily. But my Fit has alot of miles so I should be getting ready to do some things outside of my normal oil changes and filter cleanings.
It's an AT and gets a mix of city and highway driving. Which of these is too early/late/not needed to do? I've already changed the front brake pads less than a few thousand miles ago.
Change transmission fluid
Change spark plugs and wires
Change oil (when it's ready, still at 70% oil life)
Is this about all I should to at 68-70k miles? I don't think I should adjust the valves until 110k, right?
I'm hoping this is all because I'm not comfortable working on the Fit myself like I am the CRX.
Old Sep 13, 2010 | 07:54 PM
Punisher11's Avatar
shot in the dark, but timing belt and water pump? Tranny fluid from what I recall should be done every 30k
Old Sep 13, 2010 | 08:30 PM
SilverBullet's Avatar
Fits have a timing chain, no belt. Trans is a good idea if not changed yet. Water pump 110,000 unless makes noise and same for valves. Air cleaner ? Ive had 40000 mile on mine in construction and just blew it out with air. Spark plugs if mpg is bad other wise 110000 miles and no spark plug wires just coil packs.
Old Sep 26, 2010 | 11:15 AM
benjimonlee's Avatar
same question i asked but for 40k miles lol
rossftn
Jul 24, 2024 07:09 AM
OrangeSport09
Oct 24, 2018 12:15 PM
ezdealz
May 18, 2018 03:52 PM
bikerdrumr
Dec 3, 2017 09:41 AM
madtodaimax
Sep 4, 2012 11:01 PM
