noise in the rear
Old Sep 24, 2010 | 11:07 PM
danger69's Avatar
noise in the rear
I installed my springs quite a while ago and have not had any problems. All of a sudden I get clunking noises in the rear. I thought it might be my sway bar so I padded the where it mounts up to and the noise is still there. It only makes clunking noises when I go over small bumps. On smooth road there is no noise. Could it be my shocks? I looked at my springs and they look fine.
Old Sep 25, 2010 | 11:21 AM
ernesto1's Avatar
If nothing visible is loose or rubbing, it very well could be the shocks. Sometimes when shocks wear, the valving inside degrades and can make an internal noise that would not be easily found. If the shocks have a lot of miles on them I would replace them.
Old Sep 25, 2010 | 11:33 AM
Black3sr's Avatar
OP - toss her out.
Old Sep 26, 2010 | 12:26 AM
danger69's Avatar
After reading a lot of threads. I decided to tighten my shock lower bolts. And it was a bit loose so I tightened it a bit more. And what do you know no more sound. There is very rarely now and very tiny noise but hardly noticceable. Now I have to fix the tiny rattle in the front dash. And I think I read some where on here to fix it I can use some plastic air tubing to make put pressure on the dash.
Old Oct 12, 2010 | 10:14 AM
Jodele's Avatar
Ultra Racing fender bars took out my rattle in the front...
flipwidwings
May 12, 2012 07:41 PM
Hondafrk
Jan 29, 2012 09:49 PM
panda1314
May 3, 2011 08:31 AM
danger69
Jan 6, 2010 09:46 PM
kingofpicklez
Nov 22, 2009 03:31 PM
