Where can you pull a power wire for your Amp. through the Firewall??
Old Sep 30, 2010 | 04:36 PM
Perrenoud Fit's Avatar
Question Where can you pull a power wire for your Amp. through the Firewall??
So this weekend is amp. day. But I've looked over the firewall and only see were the ECU harness comes through for acsess, and the driver's side seems to be 2x wall?
What have you guys done? was there a groumet or is a hole needed to be cut?
Thankx for any info on this
Old Sep 30, 2010 | 06:26 PM
viperjh16's Avatar
were ur brake pedels is under the rug there is a hole
Old Sep 30, 2010 | 08:47 PM
lashlee's Avatar
I drilled a hole in the knockout where the clutch would be (mine is an auto). Snap in grommet and all is well!!
Old Sep 30, 2010 | 09:21 PM
^^ MzFiT's an A/T 2 thankz lashlee and viperhj16 + reps to u's 2
Old Oct 1, 2010 | 09:31 AM
Fit4Spl's Avatar
Or there is a large gromet under the dash just above the pedal assembly if you have a MT that you can pass through. You can see it in my build log on here; https://www.fitfreak.net/forums/2nd-...stall-log.html
Old Oct 2, 2010 | 06:51 AM
MzFiT is A/T so the clutch k.o. was the choice and now I headed out to finish up! TYLJ! A.
T-Y lashlee!
Old Oct 2, 2010 | 09:24 PM
The End
It turned out better than I ever imagianed it would "sound wise" . Rockford makes some great sounding componets. After dailing in the LOC80 (3/4 open) and the amp it still had more tuning to do @ the radio. Pushed the sound button and did some playing around there. But when the bass hits the whole car vibrates; Nicole C. Mullen sounded terrific! and the is sub facing the hatch (thanks shaun954)
It's a great ICE mod and very inexpencive vs. the huge sound. Can't wait to crank up my christian cds the next time a get a trunk shaker comes beside me. hehe ha
Old Oct 2, 2010 | 09:41 PM
crash001's Avatar
I drilled mine and sealed it I went under the carpet by the pedals and there is a slightly recessed circle I drilled thought it supper easy if u havean aftermarket intake I diddent wanna go though the firewall so just another place
Old Oct 12, 2010 | 11:52 PM
Scala's Avatar
on the passenger side there is a rubber stopper with a cord going through stuck my power cable through there
ck42
May 12, 2017 08:22 PM
GotFitB13
41
Mar 17, 2015 07:30 PM
Jas101
Jan 19, 2015 04:53 AM
iFit08
15
Mar 12, 2011 12:41 PM
Perrenoud Fit
Dec 18, 2010 01:55 AM
