Best tire size without rubbing?
Old Nov 13, 2010 | 02:10 AM
Remedi's Avatar
Hi, I am looking at buying a set of wheels that are 15x7 with a +40mm offset. I am a bit stumped right now and was wondering what tire size could I run without rubbing? I have a 2008 Honda Fit Sport at stock height.
ANy help or input appreciated, thank you.
Old Nov 13, 2010 | 03:48 AM
Fitting's Avatar
Best bet is 195/50 or 195/55.
Old Nov 13, 2010 | 12:43 PM
Remedi's Avatar
That's exactly what I was thinking, 195/50 or 195/55. Does anyone by any chance have any pics of a 07-08 Honda fit running 195/50/15 or 195/55/15 at stock height? Anyone with experience running similar spec 15" wheels with either of the above tire? THanks
Old Dec 28, 2010 | 12:31 AM
Remedi's Avatar
I just wanted to update this thread and say that I bought some wheels that were 15x7 with a +40 offset and had 195-55-15 tires on them. I have Progress Lowering Springs installed and with the wheel/tire set up I experience a lot of rubbing during bumps or during random dips during daily driving. I have returned them and am waiting for the same set up but with 195/50/15's to be installed on my car. I'll keep you all updated and if anyone has any of these tires please chime in with your opinions, thanks.
Old Dec 29, 2010 | 09:59 AM
mugen boi's Avatar
i think w/ ur +40 offset rims...sure rub
Old Dec 31, 2010 | 03:41 PM
Black01's Avatar
You're rubbing because of your wheel offset.
Old Jan 1, 2011 | 01:33 PM
mahout's Avatar
We have a couple of A/xers who run 195/50x15 on 15x6 rims with 40mm offset stock height and they have no problem with rubbing Those tires are about an inch shorter than stock 195/55x15 tires (23.44 vs 22.67") for better performance. With 205/50x15 on 15x7/40 you will probably have interference. With 15x6/40 wheels you might get away with 205/50x15 but its close. At least one here has.
The outer rim on 15x7/40 wheels are a half inch further out than the 15x6/40 wheel. Even tho the tread width isn't greater for 195 tires the sidewall 'bulges out' about a quarter inch further and can easily come in contact with the fender inner lip.
Additionally, the 15x6 wheel and 195/50 tires are lighter and better for accel and mpg.
Old Jan 6, 2011 | 06:33 PM
mugen boi's Avatar
i'm using G-Games 55 Tabby 15x6.5 +45 w/ 205/50/R15
rear will rub
so 1st n foremost...offset then ur rim's width the tyre
J Schmidt
Sep 29, 2017 10:53 PM
panda1314
Jan 4, 2009 09:31 PM
korky
Jun 4, 2008 03:33 AM
Frenchi169
May 13, 2008 09:38 PM
FITGD3
Jan 21, 2008 07:00 AM
