OK - can someone tell me what I should be asking for here?
Old Dec 21, 2010 | 01:58 PM
doublefit's Avatar
Short version: DD drove her Fit over a deer carcass (it was that or drive into one or more cars) about a year ago which loosened the bottom shield under the engine. It was refixed but it's come loose again and what I want to do is give her the correct terminology so when she calls the shop she can get an accurate time estimate. So: what is this part called? Is this the front splash shield? Or is it another part that I simply cannot see on those exploded part diagrams? To be honest, I thought it was bigger and flatter for want of a better description.
I wish I could check it on my own fit, but on a sad note, that was totaled a couple of weeks ago in an accident. All I can say is: let's hear it for side curtain airbags, which allowed the driver to walk away uninjured.
Old Dec 21, 2010 | 02:38 PM
doctordoom's Avatar
Supervillain
i think you're right, "splash shield." maybe someone else can confirm it.
i'm sure if you said "splash shield" and specified, "that big plastic shield that goes under the engine bay, between the engine bay and the road, they'd HAVE to know what you're talking about.
Old Dec 21, 2010 | 02:48 PM
doctordoom's Avatar
Supervillain
found it on bernardi honda's exploded part diagram for the 07-08 fit.
74111-SLN-A00 View SHIELD, FR. SPLASH $ 40.71
It's under the "body/air conditioning" Section, then select "front fender." The exploded diagram will then load.
What you're talking about is labelled as "illustration #7" right? I'd just link it to you but a direct link doesn't work.
Old Dec 21, 2010 | 02:57 PM
doublefit's Avatar
Yes, I think that's it.
Mind you, as you say, if she says that big plastic shield that goes under the engine bay, if they don't know what it is, perhaps that's not the best place to take it to.
Old Dec 21, 2010 | 03:00 PM
doctordoom's Avatar
Supervillain
hahah i agree
TorontoBoy
May 17, 2022 10:58 PM
Chiasson Cary
Jan 15, 2022 09:44 PM
Ron Belisle
40
Jul 26, 2020 12:14 PM
clairetraas
Oct 26, 2009 05:09 PM
