Honda Fit 2010 // 17" rims or must be 16" for no extra mods?
Old Dec 25, 2010 | 03:12 PM
marcelosmack's Avatar
Cool Honda Fit 2010 // 17" rims or must be 16" for no extra mods?
Hello people!
I'm new here but I'm going to buy some rims for my fit.
I live in Argentina. So I have the brazilian version of the Honda fit.
Issume is the same one as you have in the USA?
Anyhow, im wondering to get some exciting new rims!
Chek this out:
pacer 776c - silhouette rims options. View pacer 776c - silhouette chrome wheels at WheelsNext.com
I'm wondering if I can get the 17" 7.5 ones and install them without touching or modding the suspensions of the car?
My wife is going to use the car soon and she doesnt want to feel it hard like we had with our previous car. A Clio with 18" wheels .
That was a long jump because Clio had 14" stock rims and I swapped them for 18" . 215.35.18". .
But this case is different. I want to swap 16" stock rims for this 17" incredible rims!!!
Would they fit my fit? .
Or I should buy the 16" ones in order to dont mod anything in the car suspensions or whatever.
Is it a big difference for the fit to go from 16" stock to 17" rims???
Sorry for the long message!
Help me!!
Thank you!!!
Marcelo
Old Dec 25, 2010 | 05:22 PM
Light-Weight's Avatar
I don't think you will have any problem if you get a low enough profile tire.
I could be wrong though, so i would wait for some more input.
Old Dec 25, 2010 | 05:36 PM
hayden's Avatar
I don't know about the limitations of the older model Fits (GD) but on the newer ones, I'd dissuade you from buying large heavy wheels like that. Being that they are chrome, and of that style, I can guarantee you they will be heavy - possibly very heavy, and that will give you crappy "everything." Acceleration and braking are going to go down, fuel economy, ride quality, and on top of all that, on the GE, you are pushing it with 7.5" wide, depending on the offset of the wheel, which you should also confirm is not too low (keep it above +40 and you should be okay with stock suspension.) I've seen a GE with 7.5" at +35 offset and it looked like it was poking in the front a tiny bit. I wouldn't even get the 16" version of those wheels, as they will also have all the same effects I described. The stock ones are relatively lightweight and helps the car achieve it's fuel economy ratings.
Old Dec 28, 2010 | 09:03 AM
thanks for your reply!
i think that i would just get the noblesse kits for the front. (noblesse ps)
and the rear under spoiler...
paint it like the Mugen Fit...and thats it
no wheel changing then
thanks!
Old Dec 29, 2010 | 06:51 PM
mahout's Avatar
Originally Posted by marcelosmack
Hello people!
Chek this out:
Help me!!
Thank you!!!
Marcelo
Go with a 17x6 wheel with 42 to 45 mm offset and 195/40x17 (08 and prior)or 195/45x17 (09 and up) tires.
Old Dec 29, 2010 | 06:53 PM
and you think that will be just fine?
Old Dec 30, 2010 | 12:07 AM
Stock wheels weight vs this ones.
So ,the stock wheels weight is for 16" 17,6 lbs.
This pacer rims I want to get are this:
Part#:*776C-6750238FINISH: Chrome
WEIGHT: 21 lb.
BOLT PATTERN: 4x100 mm
MATERIAL: Aluminum
MAX LOAD (SINGLE): 1400 lb.
OFFSET: +38 mm
BORE DIAMETER: 73 mm
WHEEL SIZE: 16 x 7.5 in.
BACKSPACING: 5.75 in.
PRESSURE SENSORS: Yes
From 17,6 to 21 lbs. On the same 16". Am I loosing much performance?
M
superslomo
Dec 20, 2016 12:40 PM
viperpit07
May 6, 2014 06:37 PM
B-Line
Oct 27, 2009 05:56 AM
Committobefit08
Jul 10, 2009 11:16 PM
big Fit
Washington Community
May 22, 2006 12:22 AM
