I need help with Japanese language to get some rims! :)
Old Dec 30, 2010 | 08:29 PM
marcelosmack's Avatar
Smile I need help with Japanese language to get some rims! :)
hello!,
i just saw this rims and i fell in love:
link
now the issue is that everything there is in japanese, can someone help me with the choice that i've to make? and how can i contact this people to buy 4 rims with tires from this guys?
i want to get 16" rims for my honda fit 2010. GE.
please tell me which numbers i have to choose exactly?
i want 16" so i dont have to change the suspension etc.
or could be 17" and a lower profile but i dont want to loose performance ,etc.
anyhow , help me with the translate! thanks!!!
Old Dec 30, 2010 | 08:46 PM
FITMugen's Avatar
Old Dec 30, 2010 | 08:50 PM
ok but which INSET should i choose?
thanks!
Old Dec 30, 2010 | 09:02 PM
FITMugen's Avatar
You can use either 16" 7.5JJ or 17" 7.5JJ with stock suspension. Tire should be 205/50R16 or 205/45R17. Offset should be 40+.
Old Dec 30, 2010 | 10:01 PM
great!
so if i go with 17" 7.5JJ u say i can use stock suspension which means i don't have to touch it and the car would be the same meaning the driving etc?.
let me know! and thanks!
Old Dec 30, 2010 | 10:11 PM
FITMugen's Avatar
17" 7.5JJ and 205/45R17 will have almost the same diameter as stock wheels and tires, 185/55R16, with 1% deviation. There should not have any rubbing. However, mileage might suffer due to weight. If you can find light wheels and tires combination, handling should be improved due to wider traction.
I am running 18: 7.5JJ with 215/35R18 on my GE8.
Old Dec 30, 2010 | 10:44 PM
Talking
OK man. Damn. You reminded me my previous car .
A renault Clio with 18" wheels mannnnn oh yes.
215.35.18".
But I can't do that now with the fit. I have a son. And we use the car with my wife . So. I want better rims. On 17" but don't touch or lower the car profile etc.
Weight is fine. As long as the suspension works the same etc.
I have this ones in mind:
pacer 776c - silhouette rims options. View pacer 776c - silhouette chrome wheels at WheelsNext.com
Weight for 17" is 21lbs.
The stock for the fit are 17.6lbs.
Is that much more heavier? Or is just fine?
Thanks for the info!
M
Old Dec 30, 2010 | 10:59 PM
FITMugen's Avatar
I would think you have to look at the wheel and tire weight combination. You cannot compare just wheel only. If you can keep total diameter and weight close to stock wheel and tire combination, the better it is. I would assume that you have 40+ offset and stock suspension.
You can use the site below to compare speedometer deviation.
Tire size calculator
gahris
May 11, 2017 10:11 PM
diego.eleazar
Nov 6, 2014 01:00 AM
purplekush
Aug 10, 2012 12:19 PM
Tong213
Mar 7, 2011 09:31 PM
marcelosmack
Dec 30, 2010 12:07 AM
