does anyone here have squeaks in their suspension?
Old Jan 5, 2011 | 01:33 AM
spin out's Avatar
i hear something in front driver's side on dips in rd and backing out my driveway. ...this at 25,000 miles.
went to the dealer on a rainy day... couldn't reproduce the squeak.
annoyed.
Old Jan 5, 2011 | 08:52 PM
spin out's Avatar
please... please.... everybody.... not all at once.
Old Jan 5, 2011 | 09:16 PM
Ric01's Avatar
I am going to ask a dumb question at the risk of being called retarded.
Did the noise sound a bit like liquid sloshing when you go over bumps? or definitely a spring sound?
Old Jan 6, 2011 | 07:54 AM
spin out's Avatar
no sloshing. standard squeaky suspension.
i'm familiar with the sloshing fuel sound.
Old Jan 6, 2011 | 03:38 PM
gynosis's Avatar
I hear an odd squeak every now and then when going over bumps or dips. I've got Tein lowering springs though, are you on stock springs?
Old Jan 6, 2011 | 04:03 PM
it's possible that your strut is blown. check for leaks.
another area might be a swaybar bushing.
Old Jan 6, 2011 | 08:47 PM
Jodele's Avatar
I have a GD3 and had a squeak in the back...it turned out to be the Progress sway bar bolts rubbing on the Mugen springs. I replaced the sway bar bolts with flush (flat head) bolts and squeak went away.
Old Jan 18, 2011 | 02:47 AM
JeremiahRclark's Avatar
I've noticed the same thing. I think it's actually the latch on the fold-down seat in the back. Try putting the seats down in the back and see if that changes it.
Old Jan 18, 2011 | 09:22 AM
Vash's Avatar
my car started doing that before 20k miles! idk whats up, it only happens when i go over speed bumps, large and small.
EDIT: my car is also bone stock
Old Jan 24, 2011 | 11:10 AM
Jazz_Pinkz's Avatar
i'm using a TEIN S-Tech lowering spring.. and yes, i heard a squeaks from the front suspension sometimes.. after i look out for that, the cause is that the spring rubbing each other, so it makes a squeaks sound.. i've covered my front spring with a cheap garden water hose.. (i use a hose that has no steel or nylon strip in it) and now there's no squeaks sound any more..
i hope this helpfull.. this idea came from my friend who compete in my national touring championship ^^
Note : this method can be used to for OEM springs..
accordguyintake
Oct 6, 2011 02:09 PM
karprive
Jun 16, 2009 05:24 PM
pwnstar
May 20, 2008 04:35 PM
saiko
30
Apr 12, 2008 11:42 AM
Sean
May 4, 2005 04:44 PM
