?!? LED Footwell Help ?!?
Old Jan 28, 2011 | 01:40 PM
stock0891's Avatar
So i have my leds in place and have them so they turn on when my ignition is on but i wanted to run it along side with my rear defogger switch on my dash... I have the LEDs power wire in the Rear Defogger fuse slot but i cant control the power to them like i wanted to with the Defogger switch?!?! I am very puzzled with why this is any help would be greatly appreciated
Old Jan 28, 2011 | 01:53 PM
WhiskeySix's Avatar
I know other things in the car switch the ground instead of the power - might be same for this.
In otherwords, the 12v line is always connected to the rear-defroster, but the ground wire is connected/disconnected to complete the circuit.
Old Jan 28, 2011 | 03:03 PM
stock0891's Avatar
Can you Think of a way i might be able to fix this or am i SOL?
Old Jan 28, 2011 | 03:19 PM
WhiskeySix's Avatar
Hard to say, since I'm not sure what the defroster switch looks like. I assume you have it something like this:
Defroster/Switch 12V ======== +LED- ========= GND
... but that 12V on/near the switch isn't what's being on/off by the switch... try this:
Defroster/Switch GND ========= -LED+ ======== 12V
Old Jan 28, 2011 | 03:26 PM
WhiskeySix's Avatar
In other words... it sounds like you've got your +12v connected to the right thing. You just need to move your LED's ground-wire to the switched-ground controlled by the switch.
A multimeter would help to figure out what the switch is changing. You need to 'ohm-it-out'. Put the DMM in the mode that beeps when you touch the leads. Put one end to ground, and then the other to various pins on the switch. When you find the right one, the "switched-ground", it will beep/stop-beeping when you toggle the switch.
Old Jan 28, 2011 | 04:27 PM
stock0891's Avatar
alright cool thanks for all your help ill have to try that as soon as i can
James Butler
Aug 15, 2018 11:49 PM
jalmoreno
Feb 2, 2017 06:39 PM
Macswfc
Dec 31, 2015 08:00 AM
TheRegulator666
Jul 25, 2012 05:02 PM
B-Blue
Oct 4, 2011 01:00 PM
