KW issues.
Old Feb 11, 2011 | 08:49 PM
resuperg's Avatar
KW issues.
Hi All,
i have recently install an KW V2 on my GD3.
however some knocking noice can be heard from the rear.
anyone here had similar problems before?
Thanks
Old Feb 11, 2011 | 09:00 PM
LaoSiFu's Avatar
I had a similar issue and fixed it.
Have you grease up your suspension before putting it on? Also it could be a possible endlink issue as well. I suggest you go back there and torque everything to spec.
~Robert
Old Feb 11, 2011 | 09:05 PM
doctordoom's Avatar
Supervillain
? there's no endlinks on the rear, and grease what up on your suspension?
Old Feb 11, 2011 | 09:06 PM
LaoSiFu's Avatar
I should have been clear I had this issue with my Z which has endlinks in the rear.
~Robert
Old Feb 11, 2011 | 09:19 PM
doctordoom's Avatar
Supervillain
haha, well that doesn't really help him.
i'd check the rear springs and how they're seated (if they're hitting or knocking on anything), there isn't really much else that moves back there. springs, and dampers.
Old Feb 11, 2011 | 09:27 PM
LaoSiFu's Avatar
haha I guess but like you mention about how the springs are sitting he could at least retorque everything back there.
Old Feb 14, 2011 | 05:05 PM
feared's Avatar
was everything installed correctly? where do you hear the knocking coming from?
Old Feb 26, 2011 | 10:15 PM
resuperg's Avatar
thanks all,
yap i checked all installation was done properlly while the rear seems to sit firmly in place both the springs and absorber.
Old Feb 26, 2011 | 10:42 PM
Goobers's Avatar
Originally Posted by resuperg
thanks all,
I'm gonna suggest something Texas Coyote and DiamondStarMonsters brought up...
Lift the Fit up until the tires are off the ground, then check to see of there's any noise.
Then there's the less obvious question... Are the things in your trunk secure? Spare tire, jack and tools?
Old Feb 27, 2011 | 02:44 AM
danger69's Avatar
Are the shocks bolt tighten to spec? Do you have a rear sway bar? Did you change to flat head bolts for the sway bar?
Old May 10, 2011 | 01:54 PM
jdmspoonfit's Avatar
can you post some pictures? i want to see how the KW looks on the fit
peopleintheskyy
Aug 23, 2018 02:58 PM
coupdetat
Jul 1, 2013 10:21 AM
hayden
18
Apr 30, 2012 12:12 PM
GoFits
Apr 29, 2012 09:52 PM
jsr
Mar 14, 2011 08:44 PM
