Maintenance Repair questions(Preventive) 07 Fit Hatchback
Old Mar 17, 2011 | 01:42 AM
ktyler's Avatar
Finally my uncle gave me his promised gift. He gave me his 2007 Honda Fit Hatchback. Problem is… It seems to have a lot of problems lately. I only had it for 1 week and it would not start and is asking for a code- code that I don’t know how to get. My other problem is my air-condition seems to have an unstable temperature. It is not too cold and not too hot. It feels just cold (28 deg) even if it is on the coldest setting. I tried to research for this and I found out that it could be a problem on a lever within the engine bay(but no idea on what lever it is). It may have been stuck thus the air-condition cannot give out its full power. My uncle did inform me that he used to have problems with his air-condition before. It blows cold when running and gets warmer when he stops or when he is stuck at traffic. Sorry for this,if it is too long. I don’t want to create separate posts for each of my car issues.
Thank you.
Old Mar 17, 2011 | 10:27 AM
D50boy's Avatar
I'd have the battery checked out. The code that it is asking for is the radio anti theft code. That usually pops up when the battery is disconnected, getting a VERY bad connection, or completely dead. That might also be the reason it is hard to start. The code can sometimes be found on a sticker pasted onto the inside of the glove box... or you can visit https://radio-navicode.honda.com/ .... or go to the dealer with documentation showing it belongs to you.
As far as the AC, I'd have a shop check it out. It might need a simple recharge.
Old Mar 17, 2011 | 11:27 AM
kbri's Avatar
From when I lived in central Florida - the A/C behavior sounds like what I experienced when new. This car is "smart" in how it manages the engine load, and at an idle will shut off the compressor at times to reduce loading. I found the cycling kind of annoying - not liking warm air blowing on me just because I hit the brakes for a light.
28 degrees is actually quite cold for this car! Honda designed it so the evaporator coil wouldn't ice up, and so the coil temps are normally about 33 degrees - and the computer cycles the A/C compressor to keep it there.
Fweemn
Jan 20, 2020 10:28 AM
Fit22
Sep 7, 2018 09:01 PM
UnicycleWheelie
Jan 16, 2014 03:59 PM
jackson6644
Oct 11, 2013 10:04 PM
SalemMAFit
Jun 3, 2010 10:23 PM
