*** UltraGauge User Discussion Thread ***
Old Apr 5, 2011 | 03:03 PM
Krimson_Cardnal's Avatar
Cool *** UltraGauge User Discussion Thread ***
I've decided to start a thread to discuss the UltraGauge.
Right off, I am in no way associated w/ the company and have not been prompted by them or their associates in any way and have absolutely no monetary interests or gains to be had.
I just like it and figured others might as well.
I've had one for a month or so and have been using it to watch fuel trims and try to see if fuel grade has any effect on them.
Results? Forum search 'ultragauge' or 'fuel trim vs fuel grade' and see.
Thing is I was able to do it, and I'm thinking that's pretty cool.
The 'brain' of these cars has intrigued me and the UltraGauge has given me a look inside, not that I always know what I'm looking at or what it means.
Here's what it can tell me about my FIT.
UltraGauge Gauges Available - 2010 Honda Fit MT Sport
In order of selection - gauge numbers for reference only
1 % Engine Load
2 Engine Coolant Temperature (degF)
3 Short Term Fuel Trim Bank 1
4 Long Term Fuel Trim Bank 1
5 Intake Manifold Absolute Pressure (PSI)
6 RPM
7 MPH
8 Timing Advance
9 Intake Air Temperature (degF)
10 Mass Air Flow Sensor 1 (gr/s)
11 Absolute Throttle Position 1 (%)
12 Bank 1 Oxygen Sensor 1 (voltage)
13 Run time since last start (hours:mins)
14 Distance traveled with Check Engine Light On
15 EGR Flow (%) Commanded
16 EGR Flow (%) Error
17 Evaporative Purge (%)
18 Fuel Level % of fUll
19 Number of warm-ups since Check Engine Light Cleared
20 Distance traveled since Check Engine Light Cleared
21 Evaporative System (PSI)
22 Barometric Pressure - Inches of Mercury (inHg)
23 Catalytic Converter Bank 1 Sensor 1 Temperature (degF)
24 Battery Voltage
25 Relative Throttle Position (%)
26 Absolute Throttle Position 2 (%)
27 Accelerator Pedal Position 1 (%)
28 Accelerator Pedal Position 2 (%)
29 Comrnand Throttle Position (%)
30 Mass Air Flow Sensor 2 - calculated (gr/s)
31 Instantaneous MPG
32 Average MPG General
33 Average MPH General
34 Average G/H General
35 Run Time General
36 Distance (miles) General
37 Fuel Used (Gallons) General
38 Instantaneous Gallons/Hour
39 Fuel Level
40 Distance to Empty (miles)
41 Time to Empty (Hours:Mins)
42 Average MPH Trip
43 Average MPG Trip
44 Fuel Used (Gallons) Trip
45 Average Gallons/Hour Trip
46 Run Time - (Hours:Minutes) Trip
47 Distance - (miles) Trip
48 Oil Change Distance (miles)
49 Service Distance (miles)
50 UltraGauge Internal Temperature (degF)
You can see it's a rather long list. What I can tell you is that their is a need to calibrate the gauge to the car.
Really isn't that hard, the web site goes into it.
The unit displays three pages of six gauges each - that's a total of 18 out of the list of 50 you get to choose.
It will also scroll through the pages automatically if you like.
I'm looking to start feedback from users and open questions from all to get this thread rolling.
Right off I'm wondering about all those throttle and accelerator positions....
Old Apr 5, 2011 | 03:31 PM
Subie's Avatar
Whoa KC! You got some time... Oops I'm here too. Just ordered one... We'll see... I'll blame it on Evil...
So have to calibrate every time you switch cars huh? Hmmm... not like a GPS... Thought it might just self-calibrate once plugged in to the new environment... Guess I'll find out when I get it...
Old Apr 5, 2011 | 03:46 PM
TunaDaMan's Avatar
damns you...I just had to check out this thread, then I just bought one...damn impulse buy...although I'm just buying this to replace my scan gauge II my friend took from me...I couldn't pass up that awesome price.
Old Apr 5, 2011 | 04:29 PM
Black3sr's Avatar
Why does it not record my farts? Records everything else it seems.
So KC with this gauge when do you have time to look at the road? I kinda place this in the disraction catagory along with cell phones and texting.
Old Apr 5, 2011 | 05:29 PM
Oh my doubtful Canadian friend, it goes over where the other visual aids are_
Farts are always recorded by the wingman - no wingman, no problems_
edit: it will also scroll automatically through three pages of six gauges each at a user defined interval.
Old Apr 5, 2011 | 05:43 PM
I've got a pretty smart scanner_
Calibration, on the Fit at least, has more to do with the MPG and fuel displays. All the rest come straight off the ECU.
You do need to tell it engine size and fuel tank capacity. Then do a fill up and fuel used input. That should then give accurate MPG numbers.
If my FIT ran with a MAP sensor it would be different, but the MAF simplifies the set-up. pg.30-32 owners manual
I strongly suggest to all printing out the owners manual before installing.
Old Apr 5, 2011 | 06:01 PM
XJP5's Avatar
I'm definitely interested in this. I want to monitor the following (not simultaneously), but it's too much of a hassle to figure out a way to mount separate guages:
- Coolant Temp
- Oil Temp *
- Intake Air Temp
- Outside Air Temp
- Voltage
- Timing Advance
(according to their estimator, this feature may no be available through the Fit's ECU, but all other appear to be)*
Can any of you that currently own this product for a GE Fit tell me if you're able to moniitor these stats listed above. Thanks in advance. I do appreciate the feedback!
Old Apr 5, 2011 | 06:35 PM
The opening list shows all the gauges the unit will see on the Fit.
Oil temp - no
Outside air temp - no
Old Apr 5, 2011 | 06:41 PM
XJP5's Avatar
Oil temp - no
Well, as much as I would like these two measurements, there are many good stats left in the list. I'm going to purchase one this Friday for sure. Thanks KC!
I'm used to going 10 - 11 miles/ min. across the ground, monitoring every function available. Idiot lights drive me nuts.
Old Apr 5, 2011 | 06:47 PM
Now, get a Gentex 21A and you're only left with guessing the oil temp, but do get a really nice auto dimming OEM type rear view mirror as a bonus.
Old Apr 5, 2011 | 06:52 PM
DiamondStarMonsters's Avatar
I am going to be looking for a place to mount a remote oil temp. sending unit. The first place that struck me was the oil pan drain plug, but I want to see if there are a couple angled fittings that would allow me to maintain the original ground clearance or as much as possible atleast..
Old Apr 5, 2011 | 08:17 PM
XJP5's Avatar
I'll be interested to hear of your findings DSM. With hot OATs here in the Summer, I like to keep an eye on Water, Oil, and intake temps. Maybe a sandwich adapter between the oil filter and the engine block?
Old Apr 5, 2011 | 08:23 PM
SilverBullet's Avatar
Oil temp - no
Typical oil temps is 30-50 degrees higher than water temps so no real need except in racing and forgot turbo engines even though my truck dont have one. You have 1 chance a day for out side temps with the ultra gauge, the first time you start the car and read IAT. Thats as close to out side temp it will give you.
Old Apr 5, 2011 | 08:33 PM
XJP5's Avatar
Originally Posted by SilverBullet
... You have 1 chance a day for out side temps with the ultra gauge, the first time you start the car and read IAT. Thats as close to out side temp it will give you.
Good point. I didn't think about that.
Old Apr 5, 2011 | 08:47 PM
You can get a good idea about the engine by fuel trims intake temps and engine temps and timing to see if the oil is hot. It does take experience but its easily learned.
Old Apr 5, 2011 | 09:32 PM
Pruav's Avatar
Good find. I was just about ready to go the autozone and buy the scan guage ii. I like the screen of this on alot better. Even better is the price way cheaper than the scan guage.
Old Apr 6, 2011 | 12:46 PM
Post back on what you think.
Old Apr 6, 2011 | 04:01 PM
Java^FiT's Avatar
Ordered mine the other day, should be getting it tomorrow or friday, will update with my thoughts
Old Apr 6, 2011 | 09:35 PM
ThEvil0nE's Avatar
be sure to check your UG's firmware version (page 48 on downloadable pdf manual) to keep it current. if yours don't have the latest firmware, contact support as they can update it for you free of charge... you do need to send in your UG tho
Old Apr 6, 2011 | 09:46 PM
Goobers's Avatar
Wow, it's pretty inexpensive and yet fairly comprehensive. I have the urge to buy one, but realistically... I don't "need" it, so it's hard to justify buying one.
