Tire, Wheel, Brake & Suspension Welcome to the FitFreak.net Tire, Wheel, Brake & Suspension Forum
Rear Skunk2 spring clunking after install.
Old May 27, 2011 | 08:29 AM
pearl's Avatar
Just installed my springs tonight (well 3 of them, i stripped the rear strut bolt ), and my one rear spring is clunking over weight-shifting bumps.
The skunk2's have some of the coil cut off, but is covered in the rubber hose. I'm almost positive i installed them with the rubber down. I also removed the rubber from the stock spring perch. Could this be my problem?
Also, besides Honda, has anyone else used a replacement bolt from somewhere else? I highly doubt anyone will have that bolt in stock in NJ.
Old May 27, 2011 | 09:23 AM
pearl's Avatar
this is how it sits now the other side needs another 1/2 inch from the other spring.
Old May 27, 2011 | 11:16 AM
GD3_Wagoon's Avatar
try putting the rear on jackstands and rotating the clunking spring till it settles into the perch. i had the same problem with my pro-c's and that was my fix.
also check to see if it's not just your spare tire, scissor jack, or tire iron moving around in the spare tire well. i had that problem too and only realized it after tinkering around with the suspension for almost an hour ..
Old May 27, 2011 | 05:32 PM
doctordoom's Avatar
Supervillain
what do you mean by this? did you remove the entire stock rubber piece?
if you did, the clunking noise is probably from the metal-on-metal contact.
Old May 27, 2011 | 05:38 PM
pearl's Avatar
thats what i did. i ended up swapping the stock spring back in until i can replace the bolt that goes through the strut on the passenger side. oh well!
revd34
Jan 9, 2021 02:03 PM
pentium77
May 10, 2015 10:20 AM
AWDturbo
Oct 27, 2008 04:00 AM
AtticusFit
Oct 5, 2008 10:30 PM
Tofuman
Aug 31, 2008 03:24 PM
