Question about the shocks/dampers
Old Jun 15, 2011 | 02:09 PM
fittacular81's Avatar
So I've installed swift springs and have had them for quite some time now. The other day I noticed while installing headlight bulbs when I turn the steering wheel all the way in one direction, the rubber gromit where the damper is lifts up slightly. Is this happening because I need to tighten the damper more, if so what's the best approach maybe remove the wheel, have the car supported on jack stands and then jack up each front side wheel independantly so as to remove weight and compress the shock? It's kind of hard to explain.... thanks for any help or is this just normal????
Old Jun 15, 2011 | 04:27 PM
Goobers's Avatar
That movement is because there's slack between the two top nuts (one nut "under the car" and the other nut on top of that grommet).
If you want to remove that movement, you only have to tighten the top. Get a ratcheting box-end wrench (oh so much easier with it) and an allen wrench.
Old Jun 15, 2011 | 04:42 PM
Yea I've pretty much tightened it as much as I can. Using an Allen key, and a wrench. It won't thread anymore not one bit.
Cicatrix
Feb 10, 2013 05:15 PM
fidget247
May 30, 2011 03:33 PM
ramjet
Feb 9, 2011 02:08 AM
Red Diablo
Jan 10, 2010 11:31 AM
GROC80
Oct 9, 2007 02:31 PM
