Factory Alarm Horn does not sound
Old Aug 15, 2011 | 06:51 PM
mildse7en's Avatar
I have been lurking around here for a while, and unfortunately my first post must be question =(
I have searched and search and could not find an answer to this:
So the alarm on my 07 seems to have gone crazy.
When I double press the lock button, the horn no longer sounds.
When I double lock, randomly it may sound the horn.
Opening the door after removing the key, the red light on the steering column lights up solid for a few seconds. I have checked every single fuse and they all look ok. The panic button works as well. I found a grey module with a green connector under the dash, and after unplugging it, the alarm appears to work normally. Double pressing lock will always make the horn sound, however, when I unlock the car from inside after arming the alarm, nothing happens. I have driven around with the module unplugged for around 5 minutes and nothing seems wrong with the car.
Please help!
EDIT: NVM - Continued here
https://www.fitfreak.net/forums/1st-...-not-beep.html
Old Aug 15, 2011 | 08:03 PM
mildse7en's Avatar
Well if anyone is interested,
here is the link to the pdf file with the OEM security system manual
http://www.wedophones.com/Manuals/Ho...nformation.pdf
as per page 7, the car was put into valet mode
Old Mar 8, 2012 | 06:53 AM
raiderfit's Avatar
Thanks for link to the factory alarm.
Old Mar 14, 2012 | 07:47 PM
tblue32's Avatar
I have an 07 Fit when I press my alarm key it doesn't sound either. Thank I've been meaning to get to this project.
Old Feb 12, 2013 | 05:38 PM
hermanp's Avatar
I've had the same problem. I had to disconnect the wire going to the hood. Its under the hood latch. The car is now arming properly.
Yakkter
May 4, 2016 08:03 AM
teaboxx
Aug 20, 2013 03:14 AM
h22dx
Jan 14, 2010 11:59 AM
Fitting08
Sep 18, 2008 06:10 PM
GaryJaz
May 4, 2005 04:44 PM
