banging when braking while backing up
Old Aug 24, 2011 | 05:43 AM
jimsmith101's Avatar
hi,
I would like a second opinion - my honda dealership says there is no problem.
when I put my 2009 jazz in reverse and start to back up, as soon as I brake there is an audible thunk. so, more or less every time I reverse park I hear this noise.
I only noticed this sound after the dealer changed all four brake pads. nothing when I brake going forward.
hmmm.....
Old Aug 24, 2011 | 06:18 AM
413FIT's Avatar
Check your caliper bracket bolts. I had the same problem on my old civic and it was a loose bolt.
Old Aug 24, 2011 | 11:04 AM
mahout's Avatar
Originally Posted by jimsmith101
hi,
hmmm.....
I like the loose caliper too but you may have a pad that is rocking in the direction of rotation. Check your pads for a smooth FLAT surface or hangup with the piston. When you say all 4 brake pads was that all 4 wheels or just the 4 pads in front? If your rear brakes are drums there can be a 'repositioning' of the shoes there as well but I'm going to go with 4 wheel discs considering your location.
good luck.
Old Sep 7, 2011 | 09:22 AM
thanks - I'm taking the car into service on friday. I will insist they recheck the caliper bolts and for rocking pads. it's four disk brakes...
bati555
Apr 4, 2015 07:25 AM
ktbishop222
May 22, 2014 05:12 PM
FitGD4
Feb 27, 2009 07:51 AM
garciabe
Oct 7, 2007 06:46 AM
RkFast
Jun 23, 2005 10:57 AM
