Sponsored by:
Sponsored by: CARiD
back lights flickering
Old Sep 29, 2011 | 12:45 PM
HB1320's Avatar
At night I've notice the my backlights flickering non stop I got no clue what it can be if someone knows what it can be Lmk thanks
Old Jan 25, 2012 | 08:37 PM
WhiteIvory's Avatar
What kind of light bulb are you running?
It may be a bad connection.
I'm running cheap LEDs from china and they'll do that after 6 months.
I just order another set.
Old May 16, 2012 | 02:58 AM
GoFits's Avatar
I have a 2007 and yeah mine do that...and the head lights...and the dome light....
It's "Normal"
Is it a fast flicker or like flashing every second?
*edit* Things to note: When running the A/C or Radio or when using the wipers or even power windows the Voltage will dip and the headlamps will noticeably dim but should return to a "normal" brightness. On mine (and maybe your's) the vehicle lights will quickly flicker (dimming and brightening)
http://youtu.be/eVKl7w3S8Hw
http://youtu.be/LmdymvxcYik
In the first video you can clearly see the dome light flickering at a certain rate. The same rate all the other lights flicker at.
In the second video you can see the rear taillights and the license plate lights flickering for a moment (before the car apparently corrects itself.)
not sure if this helps...
Ron Belisle
Mar 12, 2022 10:08 PM
QuiGonQuinn
May 10, 2019 12:03 AM
Roger's Fit
Oct 31, 2009 02:23 AM
omfgitshimm
Oct 25, 2009 08:41 PM
Bigkatdaddy
Oct 14, 2009 01:02 AM
