Engine light came on.help please!
Old Oct 11, 2011 | 12:25 AM
bjvalencia's Avatar
Ok fitfreakers. I was driving the other night on the fwy when my engine light blinked and went away, today i was about to go to work when the engine light blinked again and stayed on this time. Im wondering whats wrong with it and how could i know the "problem code". My car have a lot of miles on it (110k). Pros, need help please.. Im getting close to changing my oil, the last time i did changed it i used mobil1 synthetic oil. Please help!!
Old Oct 11, 2011 | 01:05 AM
solbrothers's Avatar
check the code. go to your dealer and they should be able to check it for you. take that code and google it. it'll tell you your problem
Old Oct 11, 2011 | 01:36 AM
Krimson_Cardnal's Avatar
When that light comes and goes it's an intermittent problem. When it comes back and stays on it's a current problem. Like solbrothers says, checking codes is the only way to know. Take it to who you plan on fixing it, they'll figure it out. If you're inclined to find out yourself, Auto Zone, PepBoys or similar will often check codes for free and tell you the problem.
I'll take a swag and say an O2 sensor... but that's a guess.
Post back.
Old Oct 11, 2011 | 01:57 AM
bjvalencia's Avatar
Im planning on taking it to my cousins friends shop and find out whats goin on. So would i needing to replace some parts if its the O2 sensor? Thanks guys for the response which gave me a heads up of what to do. I really appreciate it.
Old Oct 11, 2011 | 02:02 AM
bjvalencia's Avatar
But how far I can drive it around?? Is it ok to drive it like 5-8miles to take it to the shop or to pepboys?im planning of having it towed to the shop.
Old Oct 11, 2011 | 02:12 AM
you should be fine. unless you have free AAA towing, i wouldnt worry about it
Old Oct 11, 2011 | 02:16 AM
bjvalencia's Avatar
Yeah..that was i was thinking,using my AAA to get it towed. Thanks guys!
Old Oct 11, 2011 | 02:19 AM
no problem! don't forget to report back with your findings!!!!
Old Oct 11, 2011 | 02:21 AM
bjvalencia's Avatar
Yeah, def i will..thursday would be the day for my fit to be diagnosed..hope ething will be all well.
Old Oct 11, 2011 | 02:28 AM
yeah. it should be all good. our cars are pretty tough. it's probably just something that needs to be replaced, like an o2 sensor
Old Oct 11, 2011 | 02:29 AM
Are you having any problems with the engine running?
I'll agree, no problem driving it till you get it serviced. The light is telling you something is wrong and you need to find out what it is.
Ignoring it and continuing to drive is what you don't want to do.
There's no way of knowing what the problem is until you have it checked out. Parts are most likely going to be needed, pulling the codes will tell you what parts. The shop you take it to will know what to do.
When the light comes on the cars computer stores a code number that identifies the problem.
The shop guy plugs a code reader into the computer and it displays the code number.
He then looks the number up and knows the problem.
There are quite a few codes, so it could be many things making that light come on.
Old Oct 11, 2011 | 02:33 AM
bjvalencia's Avatar
I noticed on my second gear the car kinda hiccups (jerk) for a reasonthat i dont know. Hopefully it wont be something big. I appreciate all your feedback guys! Thanks a lot
Old Oct 11, 2011 | 02:40 AM
Rough engine under load could indicate the O2, again it's only a guess. Are you going to need to drive it between now and Thursday??
Old Oct 11, 2011 | 02:58 AM
bjvalencia's Avatar
No,i actually drove it back home when the light stayed on. I drove my dads car to my work and will be using it too to drive to work tomorrow and thursday morning. Do u guys have any idea how much an O2 sensor would cost?
Old Oct 11, 2011 | 03:16 AM
If that's what it is, and we don't know if it is, but $200 could get you one. Then it needs to be installed.
The Fit has 2 sensors, front and rear - each priced the same.
Here's a source for yrs 09-12: CFL Honda Parts
Select the year of your car and look under Emission System/Emission Components.
The shop you go to can use this as a source for OEM or they might have another place for parts.
But don't start throwing parts at it till you know what's wrong.
Stacie Kahns
Sep 28, 2017 10:46 AM
PhilRai
Dec 6, 2016 07:12 PM
kitenok
Dec 10, 2015 07:28 PM
Rob22315
Aug 30, 2015 08:29 PM
The Barroom Hero
Mar 13, 2014 07:23 PM
