General Fit Questions
Old Nov 9, 2011 | 12:35 PM
thewwkayaker's Avatar
So a couple of probably stupid questions on my part but things that puzzle me:
1. What is the purpose of the trim piece that looks like a hat brim over the back window of the LX? You find it on lots of cars actually. Does it have a real purpose or is it just to somehow enhance the look? E.g. keep the rain off the rear window? Reduce glare from the sun? Improve the wind resistance?
2. The bar graph that shows how your mpg or L/100km - why if I'm coasting downhill out of gear does it sometimes show that my mileage is increasing ie. getting worse (I've tried in gear and out of gear - out of gear seems to be more of the issue but it happens with either)? For clarity mine is L/100km and the bar graph will often show multiple points on a coast. In fact I've had it where it topped the scale when I've coasted (this extreme seems to occur when the car hasn't warmed up). Most of the time it makes sense but there are these times where it seems to be backward.
Thanx
Old Nov 9, 2011 | 01:43 PM
Subie's Avatar
(1) My guess is you're talking about the rear "spoiler" on top of your hatch. Your guess is absolutely right. All looks. Here's an old thread if you're interested: https://www.fitfreak.net/forums/2nd-...tml#post910694
(2) If you have a new car, well get used to it first, so you can get the hang of when to pay attention to your mpg gauge and when not to. There's some lively discussions/threads about pros and cons of coasting on here.
Old Nov 9, 2011 | 01:57 PM
Interesting debate - thanx for the link
I guess I'll not bother watching that gauge. Too bad it's not accurate.
Old Nov 9, 2011 | 02:10 PM
Subie's Avatar
I don't have the gauge on my '08 but many here claim its accuracy. Just get a feel for it.
Old Nov 9, 2011 | 02:29 PM
MikeNSX's Avatar
Is there any way to eliminate that gauge?
Old Nov 9, 2011 | 02:35 PM
i though you can toggle screens... press the little control stick that's sticking out from the lens.
Old Nov 9, 2011 | 04:35 PM
Krimson_Cardnal's Avatar
Rear spoiler is a design decision I'm sure and it does help w/ snow and keeping the rear window clear.
Here's a DIY that many have embraced regarding the rear hatch: https://www.fitfreak.net/forums/fit-...wiper-mod.html
The 'gauge' your seeing is a part of the Maintenance Minder System. Read up on it in your owners manual.
It can/will become your best friend if your concerned with MPG and come to understand the related issues concerning that.
To begin, coasting, in gear, the Fit activate a fuel cutoff control to the injectors and will result in optimum MPG. Taking it out of gear or touching the accelerator under this condition will show the graph drop because fuel is being used.
K_C_
Old Nov 9, 2011 | 05:45 PM
Goobers's Avatar
Thanx
I think that bar is in MPG or kilometer per liter mode, not L/100KM. Basically, the bar is showing the most distance per amount of fuel... ie, the more bars you get, the better.
making the bar based on L/100KM could be a little difficult since the better you do, the smaller it should look... and seeing less is usually a "downer" for many people.
K_C, the Fit doesn't measure the amount of fuel ACTUALLY being injected into the intake, it bases it on something else (perhaps an "assumption" of fuel being used per rpm), which is why, when I shift out of gear, my bar sky rockets. And I can't really tell the difference in MPG in vs out of gear because of that.
Old Nov 9, 2011 | 08:56 PM
Goobers's Avatar
Sorry, K_C, I meant the Fit doesn't accurately measure for the MPG gauge. Whether the ECU actually gets accurate info at all, I can only assume so, if you guys with SG2s have fuel info to confirm fuel cut off.
Old Nov 9, 2011 | 11:21 PM
Goobz Agreed.
The MM display is really only an indicator.
I've found, however, it's a good indicator of how I'm driving and tuning an eye to it helps.
Fuel cutoff is documented by Honda as I have discovered, and you've seen [but I'll bring it forward for those who haven't]: https://www.fitfreak.net/forums/eco-...f-control.html
Only point I'm trying to raise is that the MM gauge is a good thing to pay attention to, difficult for a new owner to understand and the fact that our Fits do offer fuel cutoff economy.
Economy, it's all in how you drive it and understanding why.
BTW why aren't you strategically positioned in front of your Fit in your new avatar??? At least part of you. I've always liked that touch_
Old Nov 10, 2011 | 06:22 AM
Black3sr's Avatar
We do L/100 km here. That bar graph is rather useless. Your L/100km is the important one. I usually see 7.8 range.
Old Nov 10, 2011 | 01:20 PM
The avg L/100km makes sense. I'm seeing 6.9 sometimes 7.0 but my commute is short and half of it's hwy. I'm curious to see what my consumption will be loaded up and driving thru the mtn passes to my place in the Kooteneys
The bar graph gives some idea at times (other times not) of consumption rate so I use it as a guide but ignore it when I know otherwise.
Interesting to hear about the fuel cutoff. The engine must still be running though not cutoff completely. But if I pull it out of gear to coast it doesn't reduce/cut the fuel? Not sure I understand how it can cut the fuel without stalling the engine but perhaps someone can enlighten me.
Thanx for all the feedback though. Amazing how so many people have mod'ed their cars and learned so much about them. Great resource! :-)
Old Nov 10, 2011 | 03:12 PM
Black3sr's Avatar
Commute would be better if you drove it harder. I get below 7 on hwy at 120-130 kph on my weekly runs on 401 to Brampton.
Old Nov 10, 2011 | 03:19 PM
Stoli124
Aug 1, 2023 06:33 AM
m_x
72
Nov 16, 2018 04:10 PM
TORFIT
Jan 21, 2011 10:59 PM
climhazzard
Nov 1, 2010 11:06 AM
B-Blue
Mar 30, 2010 10:34 PM
