Sponsored by:
Sponsored by: CARiD
Rocker arm oil pressure switch replacement...
Old Nov 21, 2011 | 10:04 AM
gilbie99's Avatar
i just had my CEL come on this morning and the car is hitting the rev limiter at about 4k. car was also starting to stall when cold and was about to take it in for a valve adjustment. now this. car has 109k miles and started the bogging down this morning. did search and all points to rocker arm oil pressure switch like most people have experienced. is there a write up on how to replace the rocker arm oil pressure switch??? where is it located, and how to replace it would be appreciated...
car is completely stock. no mods, no nothing. oil level is correct.
Old Nov 22, 2011 | 10:51 AM
gilbie99's Avatar
K never mind. Found. Fixed.
Old Nov 29, 2011 | 05:12 PM
D50boy's Avatar
Mine has pulled that crap on me twice.
From what I read, they tend to go off when it is cold outside. I waited till the car was warmed up and then reset the ECU. I'll need to replace that sensor whan I have some spare $.
It's right up front next to the plastic intake cover, correct?
Old Dec 3, 2011 | 12:34 AM
gimme's Avatar
Master FitFreaker
its right at the right front (closest to radiator) area of the head/intake cover. group 10, part 12 of the image
Old Dec 3, 2011 | 03:15 PM
Marrk's Avatar
What was the outcome? Did you replace it?
Old Jan 16, 2012 | 11:15 PM
Fitn in's Avatar
Well, mine finally tripped at 98,000mi. Had the code read, reset and than it tripped again the next day. At least I could eventually get up to 75 on the fwy... got the part and then discovered that I didn't have a deep enough socket to remove the old sensor. A few minutes to Sears for a new socket, and then an easy one minute replacement. Test drive showed that all was well, but the CEL wouldn't go out. My Hyundai new product developer neighbor said it might take 10 key resets, but that didn't work. After a 20 mile drive to work the next day, it was still on, but then I restarted it and the light went out. Yeah!
Old Jan 17, 2012 | 01:26 AM
Marrk's Avatar
Glad to hear it.
You needed a longer socket or an extension for your socket wrench? Just wondering.
Old Jan 17, 2012 | 08:16 PM
taFITta_sport's Avatar
I just wanted to thank everyone for this forum. You guys don't know how much money n time I have saved with useful info like this.
Old Jan 18, 2012 | 09:24 AM
Fitn in's Avatar
Originally Posted by Marrk
Glad to hear it.
Not an extension-it's right on the front of the engine... A deep socket to fit over the sensor part of the bolt. You can't get a wrench on it, and the biggest socket that I had (or any of my neighbors had) was not deep enough to clear and reach the bottom. I think it needed a 22mm deep socket.
Old Jan 18, 2012 | 10:35 AM
Marrk's Avatar
^^Thanks, Fitn in.
Old Jan 19, 2012 | 11:28 AM
gilbie99's Avatar
So I thought I had fixed. I took it in to have a valve adjustment and that took care of the stalling. But check fuel cap came on, went away for a day and now back to the rev limiter at 4k rpm. Gonna have to read the code. Will follow up.
Old Jun 19, 2023 | 12:39 PM
str8outtapallet's Avatar
Is it an issue driving fit in this condition?
my cR stopped stalling, is it ok to drive like this until I have money to switch part out?
doctor J
Jan 29, 2019 02:04 PM
Wolfgang Kluge
Sep 14, 2017 09:21 AM
Number18
Dec 4, 2015 01:26 AM
hydrocynus
49
Feb 24, 2015 04:24 PM
oldblue
Jun 13, 2014 07:39 PM
