16x8 wheel will this FIT on 07 fit?..
Old Nov 29, 2011 | 05:15 PM
nsxfit's Avatar
I just wanted to know if anyone have this kind of set up on their FIT. Im actually looking to buy this fitment XXR 521 16x8. Will i have any issue with this set up? please advice.
thanks...
Old Nov 29, 2011 | 05:58 PM
nxtfit_08's Avatar
they will work but you have to do fender work im running 15x8 +15 also depends on what offset you get them too
Old Nov 29, 2011 | 06:20 PM
GAFIT's Avatar
Short answer is it will not fit without modifying. Now, if you are asking if the car can be modified to make them fit, the answer is yes.
AFAIK no 8" wheel will fit without work. I had rubbing in the rear with 7" +40's until I did some massaging. The factory wheels are +55...anything less than about +45 will rub.
Old Nov 29, 2011 | 06:50 PM
k24afit's Avatar
they don't fit u gotta make them "fit" by pulling ur fenders or camber,,I'm running 16x8 0 offset all around I only rub a little on the rear
Old Nov 29, 2011 | 11:45 PM
nsxfit's Avatar
Thanks for the info! ; ). I'm getting a XXR 521 rolling the fender not a problem I'm just concern about will the front wheel turn without rubbing. The wheel size 16x8 with a +20 offset and putting these tires on them 215/40/16 with just a little strech on it....
Old Nov 30, 2011 | 03:04 AM
ediddyfit's Avatar
good luck with that....if i get rims i'am not planning on any fender rolling....just regular rims that fit.
post pics when you're done
Old Nov 30, 2011 | 05:27 AM
oOopinkmanoOo's Avatar
sick this is good info!!!
Old Nov 30, 2011 | 02:47 PM
nxtfit_08's Avatar
you shouldnt have any problems at all but the size tire might be you have to go smaller like a 205 or 195 so you dont rubb as much knock to knock
Old Dec 1, 2011 | 12:07 AM
nsxfit's Avatar
alright guys thanks for the info again. I will call the store tom so they can place my order on this wheel...
thanks again....
Old Dec 1, 2011 | 12:10 AM
nsxfit's Avatar
ohhh i forgot tires that will be on that wheel is 205/40/16 not 215/40/16...
Old Dec 1, 2011 | 01:05 AM
GAFIT's Avatar
The narrower you go in tires the less work you will have to do for clearance. Just keep in mind this is not the best handling plan.
Old Dec 15, 2011 | 08:08 AM
Misfyt's Avatar
Will I need to fender roll/fender pull? I am going to get xxr 501s 16x8 +15 offset, and can't decide on what tires , I was thinking 195/50/16? I will be on Buddyclub N+ coils .
Old Dec 15, 2011 | 05:05 PM
nxtfit_08's Avatar
yeap im running 15x8 +15 on mine and i had to run camber and pull and roll fenders
Old Feb 23, 2020 | 12:32 AM
TheTickingGE8's Avatar
what ended up happening I have a set of these exact wheels I just bought and I’m now getting terrified they won’t fit.
nthusiastt
Apr 15, 2020 02:22 AM
Muster
17
Jul 4, 2011 02:46 PM
Blueputtputt
Apr 29, 2010 12:55 AM
SikxChoi
Jan 13, 2010 02:51 AM
HB1320
Feb 14, 2009 01:09 PM
