HELP.. Mishimoto D2S
Old Jan 3, 2012 | 12:37 PM
GE8Anderson's Avatar
I have a 2012 Honda Fit and i purchased this kit Bi-xenon Morimoto Mini Stage III Kit (D2S) - Complete Retrofit Kits from The Retrofit Source Inc
to retrofit and i was curious if anyone had a DIY for the D2S.
Old Jan 5, 2012 | 07:24 AM
BlueBoogers's Avatar
It'll be a very similar install to the Mini H1: https://www.fitfreak.net/forums/fit-...retro-diy.html
Old Jan 5, 2012 | 06:11 PM
My question is can I paint the reflector and projector cover black? And do you having aiming advice
Old Jan 5, 2012 | 08:18 PM
The reflector can be painted because when you install a projector it is then useless. As for the shroud, it can be painted as it's purely aesthetic. I recommend a plastic primer and then an automotive-grade flat black spray paint.
As for aiming, the rotation is set using the H4 adapter. For vertical alignment, I recommend parking about 25 feet back from a standard passenger car (Fit, Accord, Camry, etc.), and aiming the cutoff at the bottom of the side mirrors, so you know you're not blinding most cars.
Mixtape
Oct 27, 2014 09:27 AM
GoFits
Dec 17, 2012 10:06 AM
smeister
79
Nov 16, 2012 06:37 PM
cali_fitted
Feb 23, 2009 09:22 AM
andyd
Feb 11, 2008 10:40 AM
