Short Ram Intake Choices
Old Jan 28, 2012 | 11:06 PM
hiwatt357's Avatar
So, I've been looking at various short ram intakes for my 2008 Fit Sport A/T, and I've narrowed down my choices...sort of. There is a lot of info out there, and some of it is conflicting. So, I thought I would put all of my choices in a list and ask for some opinions from you Fit Freaks in regards to performance, fitment (particularly with an automatic transmission), quality, bang for the buck, etc.
It's probably worth mentioning that the previous owner of my car installed a larger battery, so that metal strap that is usually across the top of the battery is no longer there...nor is that long bolt that attaches it to the battery tray in the front. Several SRI's seem to use that bolt as a mounting point, so that could be an issue with some of these.
Here are the intakes I am considering as well as my current thoughts about each:
aFe 51-11282 Stage 2 Intake ($184.79)
This is definitely a front-runner. Many good reviews, and there don't seem to be any fitment issues. My main concern is, as mentioned above, that the previous owner of my car installed a new, probably larger battery, and that long bolt that attaches to that metal strap across the top of the battery isn't there any longer, and that's one of the mounting points for this intake.
HPS Short Ram Intake ($162.00)
Also seem to be many good reviews of this one. I sort of lean towards this one due to the fact that it doesn't use that battery bolt for mounting.
Top Fuel Power Chamber 2 ($149.99)
Interesting to me because it's not very common, but that also means that there's less information and reviews on it. I have read that some say that the sharp angle increases turbulence and, therefore, decreases performance. True? False?
DC Sports Short Ram Intake ($97.45)
Nothing particularly special about this one, it seems. Except for the price, which is pretty cheap. Not sure whether it uses that battery bolt for mounting, though. Anyone know?
Fujita Short Ram Intake ($164.99)
Many good reviews of this one, but it uses the battery bolt for mounting.
Weapon R Secret Weapon ($211.65)
Pricey, for sure. Also not sure about whether it mounts to the battery bolt or not.
Injen SP Short Ram Intake ($219.88)
Also pretty pricey. Doesn't look like it mounts to the battery bolt, though. Numerous positive reviews for Injen stuff.
So...these are what I am looking at right now. The aFe, HPS and Top Fuel are probably the front-runners at this point. However, if something like the DC is regarded as a decent intake, I'm not opposed saving $50.00 - $80.00+. Many of these don't seem to come with any sort of heat shield, which I find slightly odd.
I should also mention that in regards to performance, I am not so much concerned about any sort of big HP gain because I know that SRI's don't provide a huge boost in that area. However, I did have a noticeable increase in fuel economy with an SRI (an AEM intake) in my previous car, so I would prefer an intake that would increase my fuel economy.
Any and all comments, suggestions, information, etc. regarding these intakes are welcome, as well as other possible options.
Thanks!
Last edited by hiwatt357; Jan 28, 2012 at 11:24 PM. Reason: Additional information.
Old Jan 30, 2012 | 06:52 PM
feared's Avatar
the dc sports mounts the same way as the fujita. you might be interested in the k&n one too.
Old Jan 30, 2012 | 09:33 PM
hiwatt357's Avatar
Thanks for the input on the DC Sports intake. I get why the previous owner installed the larger battery (for the stereo), but it's seriously limiting my options for intake installation.
As for the K&N intake, I have read way too many posts on this and other forums about the fitment issues with those. So, that one doesn't really seem like an option.
I've also run across the Apexi Power Intake, which looks a lot like the APS intake, so that's another option as well.
Old Jan 30, 2012 | 10:16 PM
Btrthnezr3's Avatar
Have you thought about the PRM?
Old Jan 30, 2012 | 11:07 PM
hiwatt357's Avatar
I have looked at it, but at $289.00 (including shipping and handling), it's a bit pricey. I mean, is it $130.00 better than some of the others?
Old May 28, 2012 | 01:13 AM
arcadence's Avatar
Reviving this older thread, but which one did you end up with, and are you happy with your decision?
Old May 30, 2012 | 10:03 PM
hiwatt357's Avatar
I read several posts on here and other forums that indicated that the Fit engine ran better with the stock intake, so I have left it stock for now.
In addition, I think that my current battery size will cause some issues with the fit of many intakes.
I may still install an intake at some point, but for now, it's still stock.
Old Jun 11, 2012 | 09:26 PM
DOHCtor's Avatar
I have the Fujita SRI on my A\T Fit and it works great but thinking twice about it, i should have bought the Injen CAI that works with the A\T transmission! The longer pipe would probably have robbed less low end torque! Fortunately, my DC Sports Header gave me back the low end i lost with my SRI....
Marko!
Old Sep 15, 2012 | 02:40 AM
sh00k's Avatar
Marko!
So there is a cai that works with the AT fit. Is it for the GD or the GE? Also is there any mods that you have to do to make it work or does it bolt on?
Old Oct 15, 2012 | 10:18 PM
jdmkira's Avatar
Go with the Weapon-R with a K&N Filter; gave me 8whp,
Old Oct 16, 2012 | 09:57 PM
AJR Jay's Avatar
Not quite as short ram, but definately consider the T1R intake. One of the best ones on the market.
A&J Racing :: Specials :: T1R B-Max Carbon Intake - Honda Fit/Jazz 06-08 (GD3/GD4)
Thanks.
Jason @ AJR
Old Jun 6, 2017 | 01:36 PM
crazy_shadow's Avatar
rise from your grave old thread......i have been reading and hearing that putting any kind of air intake on the fit is pointless because the ecu resets making any gains not work, is this true for any year or just certain ones? or what!
Old Jun 15, 2017 | 12:24 PM
Sid 6.7's Avatar
Why so serious?
My Sid Short Ram (SSR) intake seemed at the very least to improve fuel economy. Anytime you increase the CFM of air entering the cylinders, you have the capacity to make more power/be more efficient. The ECU doesn't negate this by "resetting". Om fact you WANT an ECU smart enough to know to add more fuel to compensate for increased CFM into the combustion chamber
Old Jun 15, 2017 | 03:31 PM
Myxalplyx's Avatar
No, it is not! Made a whole thread on this (Great Intake Test). My 1/4 mile time improved by .2-.3 and my trap speed by 2mph with the addition of a cone air filter on the maf sensor, which was attached to the throttle body. It was not a pretty looking setup but out of all the intakes I made, this one was the best overall. It is considered an SRI as well as a CAI.
I bracket race my cars. I've only bracket raced this one twice last year and won at a Honda Day event. The car is consistent. It would not be consistent and this quick if the ECU was resetting and making gains not work. As a matter of fact, I have not experienced this with any of my cars that I have put on an intake. But that's outside the scope of your question. Never had this issue on the Fit though.
Old Apr 30, 2018 | 06:04 PM
evilchargerfan's Avatar
while not exactly "good looking", I gotta say, that air box looks like it probably works damn well
Allyoopski
Nov 15, 2016 08:10 PM
jbbuilt
Sep 26, 2013 12:38 PM
lowkeymods
Jan 9, 2012 04:51 PM
Mr_Kunio
Feb 21, 2010 04:53 PM
Fitamusprime
Aug 18, 2009 08:49 AM
