Anyone have actual pics of door speakers installed?
Old Jan 30, 2012 | 09:45 AM
dewthedew's Avatar
i just searched like 15pages of ICE forum and found none lol
Im just trying to see how you guys are mounting aftermarket speakers
Old Jan 30, 2012 | 05:12 PM
lashlee's Avatar
Here is a pic that I have on my install log:
Here is a link to the page for you to look at: http://www.cardomain.com/ride/388189...t-hatchback-4d
Old Jan 30, 2012 | 07:09 PM
feared's Avatar
dont have a pic, but mdf spacer screwed to door, speaker screwed to spacer. I cut out my door panel to house speaker with larger basket.
factory cut out is tine.
Old Jan 30, 2012 | 08:24 PM
BlueBoogers's Avatar
MDF spacers, preferably covered in bedliner material
Old May 15, 2012 | 03:48 AM
Gffy2334's Avatar
Since I'm on my second set of MDF spacers, is the bedliner for weather proofness or something else?
Old May 16, 2012 | 06:08 PM
lashlee's Avatar
Yes the bedliner should help with the water. I've done it with bedliner as well as fiberglass resin and used other materials that are weather resistant.
Old May 16, 2012 | 06:52 PM
Gffy2334's Avatar
Thanks a bunch. I was deployed when my car was flooded from rain.
If you read stuff from a while back some people experienced rain that would pool up into the back seats of the GD's when you left them parked in a rainstorm with the hood facing higher ground.
Almost a year later when I came back from Japan I discovered my mdf spacers had swollen and were no longer holding the speakers tight any longer.
I probably won't take out my current speakers just for the sealant application but if I upgrade or discover another problem it'll happen in the future.
Old May 17, 2012 | 09:24 PM
lashlee's Avatar
If you need them I can make a set of the ones that I made, using some material that is impervious to moisture. They are the ones in the picture above. They are expensive but I can cut them to any size with a perfect circle cutter.
jnesselroad
Apr 16, 2011 04:38 PM
FITment
Dec 28, 2010 10:11 AM
NipponFit
13
Dec 21, 2010 09:49 PM
EMC2
Oct 27, 2010 03:19 PM
Mervby
Jan 16, 2007 07:54 PM
