Bad coil, Bad plug, or worse?
Old May 15, 2012 | 08:42 AM
kbh's Avatar
kbh
My 2008 Fit Sport with 59 K miles seemed to be anemic going up hills. No CEL's and fuel economy was so-so, about 27 mpg mostly city driving. I decided to do a more extensive service including changing spark plugs, air filter, oil & filter, and seafoam treatment. I pulled the coils and found one was quite dirty and the corresponding plug was also dirty. Of note, the dirty plug seemed to be seated much more loosely when I was removing it with my socket wrench. Could it just have been improperly torqued from the factory? Or do I need to be more worried about a cracked head? For now I will reinstall the coil with a new plug (at proper torque) and cross my fingers... Any experience appreciated
Old May 15, 2012 | 11:56 AM
mhadden's Avatar
Holy cow! When you put your new plug in, did it give you any problems going in? It definitely doesn't look like it was even threaded into the head- there's a lot of heat-related discoloration (and frankly, I'm surprised it didn't give you an indication of a problem sooner!). I would've replaced that particular coil and recheck both the coil and the plug in a few thousand miles. If there continues to be discoloration, there is an issue with the head.
EDIT: You may not be the only one. If you pulled those out in order, I found another thread at another forum that indicates that basically there is a problem with the #3 coil/plug. Look at the discoloration. The thread is so old with no updates, that one can only speculate.
Old May 15, 2012 | 05:45 PM
kbh's Avatar
kbh
The new plug threaded in easily and when I started the car, it seemed to idle more smoothly and with less ticking. I'll report back after some more high-revving drives
Old May 23, 2012 | 01:14 AM
sloganmartin's Avatar
I'm anxious to check this myself as I'm experiencing the same thing. Let us know how it's driving!
Old May 23, 2012 | 01:26 AM
n9cv's Avatar
Please let us know what you find. I'm really interested in what caused this. One would think this is more than a loose / defective plug. Let's hope replacing the plug fixes the problem.
Old Sep 15, 2013 | 04:26 AM
kbh's Avatar
kbh
Check your plugs regularly...
My Fit is now at 86 K miles. It is primarily my wife's car, but I drove it yesterday and noted a rough stumbling idle when I was waiting at a stoplight. I also filled the gas tank and calculated a really miserable 23mpg.
I took another look at the coil packs and this time both #2 and again #3 were discolored by combustion buildup because the spark plugs had worked themselves loose. I retorqued all four back down and reinstalled the coil packs and now the engine is idling smoothly again. What a PITA... Will need to check this with every oil change from now on.
Old Sep 26, 2013 | 01:27 PM
PhitAzz's Avatar
What's torque spec for the plugs?
Old Oct 1, 2013 | 08:28 PM
kbh's Avatar
kbh
I believe 13 ft-lbs.
The car is stumbling again. I went ahead and ordered four new coil packs and plan to replace all the originals and keep the two that are still pink. Will report back after a few hundred miles.
Old Oct 7, 2013 | 05:10 AM
kbh's Avatar
kbh
Four new coils installed and the car is happy again. Idle is smooth and the car cold starts much more easily.
Old Oct 7, 2013 | 07:33 AM
_iFit's Avatar
I'll keep my eye on this as well. glad its resolved.
good info thx
mhmmmatthew
Nov 21, 2011 01:18 AM
D50boy
Oct 19, 2011 12:36 PM
bigtymer8700
Jul 19, 2011 08:39 AM
xonexlifex
30
Jul 23, 2010 08:10 AM
phatboycrxhf
May 24, 2010 12:27 AM
