headlight housing
Old Jul 24, 2006 | 09:03 PM
FikseRxSeven's Avatar
headlight housing
what material is the headlight housing made of? glass? plastic? metal?
i know that the lense is plastic, curious about the base part where the bulb goes into.
im looking into the new osram 85/80 h4 bulbs that put out more light than 90/100 h4 bulbs.
Old Jul 24, 2006 | 11:07 PM
aallbbeerrtttttt's Avatar
it's usually plastic
Old Jul 28, 2006 | 06:48 PM
LiL Wee FIT's Avatar
Even if the reflector / housing doesn't melt.. your wiring may melt. Its best to stick with stock wattage.... just my suggestion.
Old Jul 28, 2006 | 08:49 PM
aziatiklover's Avatar
Master FitFreaker
plastic.........................
Old Aug 22, 2006 | 07:53 PM
Jimmy101's Avatar
you can get some wiring adapters for higher wattage bulbs on ebay.
Let us know how it works out!
Old Aug 22, 2006 | 11:40 PM
i ended up opting for the osram hyper 65/70 it is a very big improvement from the stock 55/60 bulbs
Old Aug 24, 2006 | 10:16 PM
Jimmy101's Avatar
Is it correct to say the 60/55 watt, consumes 115 watts with the high beam on? so 85/80 is ok, as low as you don't turn on your high beams???
Old Aug 25, 2006 | 12:12 AM
no that is not correct, there are 2 fillaments in the bulb, and each of them burn only one at a time. so either you are burning 55w or 60w ... not at the same time
Old Aug 25, 2006 | 12:15 AM
Jimmy101's Avatar
thats what I was wondering. so high beams are only 5watts more?
Thats a lot of extra light for 5 watts, no???
Old Jul 1, 2007 | 12:00 PM
timot_one's Avatar
You can also make your own wiring harness to use the OEM connectors to trigger power directly from the battery.
JodysTransmissions
Feb 22, 2017 03:48 PM
emotionr
Apr 5, 2013 03:33 PM
mxl180
Aug 3, 2010 05:35 PM
mxl180
Jun 17, 2010 04:27 PM
crushbent
Apr 20, 2008 06:08 PM
