LED bulb replacement for brake and turn signals just not bright enough!
Old Jun 18, 2012 | 10:14 AM
DigitalDude65's Avatar
I tried replacing my brake and turn signal bulbs with LED's, but the brightness was just not enough, especially for the amber turn signals. The incandescent amber turn signals were SO much brighter. The brake lights were just a little dimmer, but I was shooting for much BRIGHTER.
Corresponding with LED_Option about the The LEDOPTION_7443_L44 (brake) lights, I got this response:
"The 18 SMD is equivalent to 54 LEDs as each square has 3 LEDs in it.
30, and 40 count have single leds per square.
So the 18 SMD should be the brightest."
The amber turn signals were LEDoption BAU15s PY21W 18 counts SMD Corner Signal Blinker Backup Reverse Light LED bulbs 7507
So, my question is, is there some other option? What can I use to get LED's that are as bright as the stock incandescent? Are there BRIGHTER incandescent, maybe?
DigitalDude65
2012 Fit Base
Old Jun 18, 2012 | 11:32 AM
Steve244's Avatar
the incandescent bulbs are all the same wattage. If they made them any brighter they'd be burning out fuses. LEDs draw a fraction of the wattage so they can be brighter without worry. I'd look for a different brand of LED light. There is a big difference between individual LEDs.
Here's Sylvania's specs for the stop light bulbs. The lumen output for incandescent is 440Lm. This is the number to use to compare with LEDs and what you want to beat.
Old Jun 18, 2012 | 12:11 PM
Thanks for the info! It seem most LED web sites don't post the lumens, unfortunately.
Old Jun 18, 2012 | 02:40 PM
lowkeymods's Avatar
Yep, I've played around w/ lots of LED's keep at it. Also might want to look at the # of LED's in the bulb it varies from 1-36+
Old Jun 18, 2012 | 02:55 PM
Any recommendations?
Old Jun 18, 2012 | 02:56 PM
lowkeymods's Avatar
Several people including myself have had success w/ these: LED Lights For Cars | LED Bulbs | 12 Volt - Super Bright LEDs
Click the more info button and you can see pics too.
Old Sep 9, 2013 | 03:51 AM
carl12's Avatar
One of my friends bought some 18-LEDs 1157 led bulbs from 1157 (BAY15D) 18 SMD LED Replacement Bulb, LED Tail/Brake/Turn Light last year.
I have read many concerns about LED bulbs not being legal for road use, not compatible with the actual reflector optics, not bright enough, and also causing glare at some angles.
Also, many LED bulbs do not reproduce the required brightness change when braking, being sometimes only 1/5th brighter than during taillight operation.
I would also have legality concerns about using a dual-color bulb for blinkers.
What do you guys think about legaliy of aftermarket LED bulbs?
Old Sep 9, 2013 | 08:52 PM
connor55's Avatar
You need to check out vleds V3 triton led bulbs. They work differently than every other bulb mentioned here. rather than using 20-50 leds all pointing in different directions, they use 3 very high power philips leds that are focused together into a lens that mimics the output of an incandescent bulb. By doing that, it'll have the best chance of working properly in the signal reflector.
There tons of videos of them on YouTube in daylight, nighttime, direct sunlight, and off angle. In EVERY case, they are brighter than regular bulbs.
I just ordered a set of ambers for my front signals and will post a video comparing it to the stock signals when I get them.
www.youtube.com/watch?v=L_Vw7LjfNNM
www.youtube.com/watch?v=wCJSfxtZm2E
This is in direct sunlight, as much glare as you'll ever get. And you can still clearly see the tritons!
www.youtube.com/watch?v=fb_qsebogGU
Old Sep 9, 2013 | 10:23 PM
13fit's Avatar
EBAY
Make sure the auction if you purchase lists brightness like mentioned above.
Ive had success with SMD bulbs that had 25+ each bulb, and generally on ebay they go for under 15 per bulb
Old Sep 10, 2013 | 12:26 PM
PaleMelanesian's Avatar
I have ones from SuperbrightLEDs. The brightest ones they sell are near-perfect match to OEM brightness.
Old Sep 10, 2013 | 12:36 PM
FitStir's Avatar
Originally Posted by connor55
You need to check out vleds V3 triton led bulbs. .......
When you put them in for the turn signals, do you experience hyper-flashing?
Old Sep 10, 2013 | 01:12 PM
connor55's Avatar
^ nope they include load resistors/ control boxes to address this.
Old Sep 10, 2013 | 01:19 PM
FitStir's Avatar
In the actual LEDs?
or that little in-line resistor box?
Old Sep 10, 2013 | 02:36 PM
connor55's Avatar
There's definitely a little box, I'm planning to just tape it to the side of the headlight. The connectors for the original bulb plug right into the box and the box into the led.
Old Sep 10, 2013 | 03:16 PM
FitStir's Avatar
Holy Sh@t.... $100/pr for the Triton v3's???
Old Sep 10, 2013 | 03:37 PM
connor55's Avatar
You get what you pay for lifetime warranty, and made in USA. Not to mention brighter and fuller than incandescents.
Old Sep 10, 2013 | 03:46 PM
FitStir's Avatar
^^^ I agree quality over quantity.... but $100 for a pair of bulbs... wow.
Old Sep 10, 2013 | 04:16 PM
connor55's Avatar
Yeah a bit steep, but after reading plenty of positive reviews and seeing all those videos, I couldn't resist. I can't wait to see how they turn out on the fit.
jbsf3
Oct 22, 2015 12:08 PM
XXXG-00W0
Nov 25, 2014 01:42 AM
xonexlifex
May 18, 2011 03:51 PM
kakrohn
Apr 5, 2010 07:18 PM
txmatt
Feb 17, 2009 02:46 PM
