Phase 2: GD3 Turbo Build
Old Dec 1, 2012 | 04:33 AM
gynosis's Avatar
Planning ahead, as I like to do, I'll be picking a spare L15A sometime next year (April/May most likely) and building that up on the side.
Parts I'll be looking at include the following:
-LSD, need input on which brand to choose please...Going for a gear type instead of the clutch type.
-Rods, Pauter? K1? What else is available? Been out of the scene for a bit
-Pistons, I'm thinking CP or Wiseco.
-Bearings, Clevite or ACL?
-Head studs, bolts, etc. ARP?
-Head gasket, OEM.
-Cam? Only thing I've seen is Bisimoto and JUN...
-Valve springs and retainers? Bisimoto again I'm guessing?
-Port and polish
-Cryo treatment on the camshaft.
-New intercooler (different size and core type)
Sticking with the TD04L and upping the boost Might change the turbo then but I'd like to see how far the TD04 can go. At this point I may have to look at running a full standalone system, probably gonna go with AEM.
If I've left anything out please let me know, just thinking off the top of my head here.
PS, current set up:
RDX 410cc injectors
AEM water/meth
AEM FI/C
Walbro 255l/ph
Log manifold (ceramic coated)
TD04L + turbo blanket
63mm stainless exhaust (1box), cat delete/down pipe.
Old Dec 4, 2012 | 07:45 AM
gynosis's Avatar
92 views and no interest or input?
Old Aug 7, 2013 | 12:04 PM
dewthedew's Avatar
Search Results : Bisimoto Engineering, Where Efficiency Meets Technological Perfection
Bishi has a bunch of stuff when you search L15A..
I want to grab a second L15A to build :noes:
Old Aug 7, 2013 | 05:11 PM
TPColgett's Avatar
Tagging for future updates!
Old Aug 13, 2013 | 06:03 PM
gynosis's Avatar
Budget, goal and power considerations in place this is what my shopping list looks like:
-Kaaz LSD 1.5 way Super-Q
-K1 Rods
-CP pistons (coated)
-Clevite bearings (rod and mains + treatment)
-Innovate Street Spec Engine Mounts
-AEM Series-2 engine management
-Velocity stack
-Consumables (gaskets, oil, filters, etc.)
Aiming for 12psi/0.8bar boost on the TD04, stock sleeves should be up to task, expecting anywhere from 160-200wkw/218-272whp.
supersuave89
18
Nov 15, 2016 07:11 PM
Gandankenexperiment
Jan 26, 2016 03:37 PM
RBMvrk
73
May 9, 2014 07:31 PM
porkchop
Mar 1, 2009 04:16 PM
tonyd3773
Mar 15, 2008 09:19 PM
