Fitment question: 15x6.5 +38, 195/55/15, GF210. Rub?
Old Feb 12, 2013 | 04:11 PM
Bull's Avatar
I just got done looking through the shoe thread and didn't find exactly what I was looking for. I just picked up an 07 Fit Sport for my wife. The plan is to go down with Tanabe GF210 springs and add some new wheels. Wheel specs are 15x6.5 +38. Tires are 195/55/15. Will this set-up rub?
Old Feb 12, 2013 | 05:22 PM
TPColgett's Avatar
The only offset that appears to work for most people to be rub free is at least a 45.
That being said, for a 38 15x6.5 it's only likely to rub in the rear when loaded and MAYBE in the front under hard cornering/bumps. I plugged the numbers into this calculator to compare to the OEM sport wheels Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
and you will stick out 0.6inch or 15mm more toward the fender.
I run a 15x7.5 32 offset with 195 50 15 for AutoX and I am on Swift springs. I have a ton of camber (-3.0 up front) and have pulled my fenders as well as the "fender liner flip trick." I also rolled my rear fenders to make that clear. Although, with that much modification I have been able to run a 15x8 25 offset with 225 45 15 tires
Old Feb 12, 2013 | 05:26 PM
Bull's Avatar
What are the stock wheel specs for comparison?
Old Feb 12, 2013 | 05:29 PM
TPColgett's Avatar
OEM Sport alloy is a 15x6.0 53 offset
Old Feb 12, 2013 | 05:36 PM
Bull's Avatar
Seems your scenario isn't quite apples to apples with what I'm proposing either though. Your set-up puts the lip of the wheel 1.24 inches closer to the fender lip than what I'm looking at just based on the numbers.
Old Feb 12, 2013 | 05:45 PM
TPColgett's Avatar
Yes, my setup is VERY aggressive and significantly wider.
I was only listing it as an example of what is possible.
Before I made any camber or fender modifications, I was able to run a 205 50 15 tire on a 15x6.5 40 Rota with zero rubbing issues. That's at least closer to what your asking I guess.
Old Feb 12, 2013 | 05:48 PM
Bull's Avatar
The Rotas was with the Swift springs? 1.4/0.8, right?
Old Feb 12, 2013 | 05:49 PM
TPColgett's Avatar
All of my setups are on the Swifts yes.
Since the GF210 is listed at 1.5/0.9 it should be very close
Old Feb 12, 2013 | 05:50 PM
Bull's Avatar
Any pics of that set-up? Any pics of the set-up I'm proposing? Just trying to get an idea of what the stance will look like too.
Old Feb 12, 2013 | 06:08 PM
TPColgett's Avatar
These would be examples of my 205 setup on the rotas on Swifts
Old Feb 12, 2013 | 06:24 PM
OP, if you get the springs/wheels in your OP just get a 195/50/15.
You should never, ever rub with that setup. If anything you can always just tuck the front fender liners, but with that sizing you should be fine even without that.
Old Feb 12, 2013 | 06:28 PM
TPColgett's Avatar
Wont adjust the speedo by much, maybe 3% and should provide slightly better handling (at least I notice quicker turn in on that size.)
Old Feb 12, 2013 | 06:51 PM
DreaMv's Avatar
i had 15x6.5 +38 195/55/15 on GF210 years back..
never rubbed D:
Old Feb 13, 2013 | 10:25 AM
Bull's Avatar
never rubbed D:
Thanks! Would you happen to have pics of that set-up?
Thanks to all who have replied!
Old Feb 13, 2013 | 06:55 PM
DreaMv's Avatar
i only found one lol.. from late 2010 i think
Remedi
Jan 11, 2013 07:02 PM
SikxChoi
May 16, 2012 04:53 PM
Misfyt
Apr 20, 2012 01:45 AM
HB1320
Feb 14, 2009 01:09 PM
korky
Jun 4, 2008 03:33 AM
